Performance mods?
3.54s or 3.73s would be fine, and though some will recommend a 2600 stall TC or higher for an LT1 car, I would personally go lower, 2200-2400, because of how they feel when youre driving around town.
You need to get a ring & pinion, you don't have to buy a whole new D36 or D44, and have it installed by a good shop. You will want to buy gears for the 2-series D36 case. Any transmission shop can swap out a TC.
Do those things and see how you like it, changing cams requires some thought and goals in mind, but you will want to have had these two things done already then anyway, so do these first.
(330/2.59) * 3.06 = 390...which is a gain of 60ft/lbs of TQ -- on an engine dyno.
Typically though...rear wheel numbers are about 85% of engine dyno numbers (due to drive train losses). 330*.85=280rwtq
(280/2.59) * 3.73 = 403rwtq
So, if you converted to 3.73 gearing, it would FEEL like you had a 120ft/lb bump in torque....(in 3rd where the gear ratio is 1).
Another way to think of it though....is you'll have a super-low 1st gear, 2nd will react more like 1st, 3rd more like 2nd, and 4th would feel like 3rd. And, actually, I think you'd be running higher in rpms in 4th than you are in 3rd now. That's probably why ddahlgren suggested 3.06 gears because it's not so extreme. It's definitely why he pointed out your speedo would be way off unless you changed the speedo gear.
If you consider a gear change, query/search for feedback before choosing your gear ratio. I'm fairly certain you can find whatever ratio you'd want....not just 3.73s.
He is correct is pointing out ZF6 cars come with the larger rear end. If you choose JUST to do the gears, "performance" automatics mostly came with the 3.54 gears. Still D36 AFAIF though.
I never memorized the RPO codes because mine came with D44 3.33 ZF6...so I've never really considered a gear swap for my car.
Last edited by GREGGPENN; Jan 26, 2018 at 05:05 PM. Reason: Fixed Dana 36 case ID...after Vader pointed out my mistake!
If it were my car, I'd do gears first, then a cam after if I felt it still needed more.
