Car won't start after turning off...
Old Oct 12, 2002 | 03:50 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
Default Car won't start after turning off...
After driving his car, my friend experiences this.... he drives until it reaches normal operating temperature, and then if he stops and tries to restart, he cannot. It is a stock '85 coupe. Any suggestions ? If he waits until it cools off, he can restart it.
Old Oct 12, 2002 | 05:54 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
Default Re: Car won't start after turning off... (Electron Blue '02)
'85 Doesn't have VATS so you can rule that out right away. My '85 was doing the same thing and it turned out to be a "heat soaked" starter. This is a weird condition, difficult to really "prove" since if you take the starter off the car to test it works fine, only acting up under extreme heat. Does it work fone if he lets it sit for about 20 mins? That's what mine did, but a jump would give it enough juice to turn over.
We replaced the starter with a high torque mini starter and have had no problems since. :cheers:
I'm sending this to C4 tech so it will be answered by others with additional expereience and expertise :cheers:
Old Oct 12, 2002 | 08:01 PM
ittlfly's Avatar
ittlfly
Default Re: Car won't start after turning off... (thrills)
Does the engine turn over? Or is the starter not engaging? If it turns over and won't start at normal temps, I'd be suspect of the fuel system. Possibility a bad pump.
Old Oct 12, 2002 | 11:42 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: Car won't start after turning off... (ittlfly)
Starter heat soak for sure
Old Oct 13, 2002 | 01:37 AM
jfb's Avatar
jfb
Does the starter motor crank the engine when it is hot?
Old Oct 13, 2002 | 11:19 AM
Mr. Wonderful
Default Re: Car won't start after turning off... (jfb)
Doesn't crank... no nothing unless he waits until engine cools off.
Old Oct 13, 2002 | 12:13 PM
thrills's Avatar
thrills
Moderatrix
Definatly sounds like heat soaked starter :yesnod:
Old Oct 13, 2002 | 12:49 PM
jfb's Avatar
jfb
The starter motor is sealed, so a garden hose can cool it off and you can prove that it is heat soaking or not.
To Car won't start after turning off...
