goodbye 84 hello 1991 codes c12 and h44
Old Jan 24, 2018 | 04:08 PM
ToniJ1960's Avatar
ToniJ1960
Default goodbye 84 hello 1991 codes c12 and h44
I traded in the 84 on a 91, from a forum member it turns out.
Known issues, abs is disconnected as the pedal would kick against you trying to apply brakes at low speeds. So that will need to be addressed.
Showing a steady check engine light after driving or idling, pulled the codes and all I got was a C12 and H44.
He says he replaced the o2 sensor or sensors and it still does it. I notice the h44 code says o2 sensor (lean condition) so I think maybe something besides the sensor triggering the code.
The first thing Im doing is reading the pellet in the keys, the ignition I read 11.73 k I think theres an 11.30 k so its probably drifted some. Is this a number 5 pellet?
Any ideas or suggestions for a new 91 owner?
Old Jan 25, 2018 | 02:36 PM
Kevova's Avatar
Kevova
Lean code would be a vacuum leak(s), low fuel pressure, restricted fuel filter, AIR system, exhaust leak near O2.
The pellet in the key will cause a no start and it is only monitored when ignition is rotated to crank position. Any place that cuts car keys should be able to tell you what blank you have. I doubt they would charge you, if you only have one I would get a spare or at least a cheap steel blank traced with key code.
Old Jan 25, 2018 | 04:28 PM
ToniJ1960's Avatar
ToniJ1960
Im thinking vacuum leak somewhere too if I tap the gas the rpms keep increasing for a second or two after I take my foot off.
Also the ins mpg jumps around sometimes if IM driving steady it will go from 23 or 24 to 35 or 40 omething big jump up and baxk down.
Also I put gas in today and whoosh the air came out of the tank scary
To goodbye 84 hello 1991 codes c12 and h44
