Transmission shift weird
Old Jan 25, 2018 | 09:48 AM
Brenden Schaeffer's Avatar
Brenden Schaeffer
Default Transmission shift weird
I got a factory service Manuel but can’t exaclty fine anything in there about this certain issue. The shifts from 1st to 2 Nd is relatively smooth but the shift form 2-3 takes for ever like it will stand at 3,000 rpm or mkre depending on how my gas u give it and 2 seconds later it will shift but after that 3-4 is fine. I don’t know transmissions so what do you guys think?
Old Jan 25, 2018 | 10:29 AM
383vett's Avatar
383vett
Sounds like your tranny is slipping. Most likely a rebuild is needed. Fluid burnt?
Old Jan 25, 2018 | 12:27 PM
Brenden Schaeffer
Hmmmm how much is that about?
Old Jan 25, 2018 | 12:42 PM
arbee's Avatar
arbee
Probably in the 2000.00 range.
Old Jan 25, 2018 | 12:50 PM
ctmccloskey's Avatar
ctmccloskey
That depends on where you live and who you know. I could remove the transmission if I had to but I have never rebuilt an automatic so I paid for the whole job.
Here in Northern Virginia auto services are normally expensive. In rural America I am sure it is cheaper. If you have a relative at a Transmission shop you will save even more (Potentially, if they like you).
Have an automatic transmission expert look at it before you tear it out.
I had my 700-R4 overhauled and it was ~$1400. It really boils down to how much damage there is. Mine had just started to slip and the fluid was nasty at 90,000 miles. I chose a shop locally that removed it and overhauled my transmission and re-installed it. I was shown the insides of my transmission and explained to me just how it wore out while it was being worked on. The owners were very upfront and shared their knowledge and experience with Corvette automatics and their potential issues. The shop is still there in case I have any more problems.
Stay away from people selling rebuilt transmissions on the internet or EBAY. I am sure there are good experiences with ordered online transmissions but we have seen many bad experiences where the customer can't get satisfaction and ends up spending a lot more.
I hope that you can get your transmission working properly without breaking your bank.
Old Jan 25, 2018 | 01:39 PM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Flush and re-fill with AMSOIL SuperShift !!! End of problem !!!!!!!!!
Old Jan 25, 2018 | 01:44 PM
arbee's Avatar
arbee
Much like quitting smoking after the Dr. tells you you have lung cancer. Not likely to accomplish anything. If fluid was the problem, why does the OP not describe the problem elsewhere than 2-3 shift?
Old Jan 26, 2018 | 12:16 AM
Brenden Schaeffer
Originally Posted by ctmccloskey
That depends on where you live and who you know. I could remove the transmission if I had to but I have never rebuilt an automatic so I paid for the whole job. What
Is the transmission a 700-R4? Or is it different for my year?
Old Jan 26, 2018 | 12:29 AM
arbee's Avatar
arbee
You haven't told us your year.
Old Jan 26, 2018 | 12:34 AM
Brenden Schaeffer
Ohp my bad it’s a 1992 coupe
Old Jan 26, 2018 | 12:46 AM
arbee's Avatar
arbee
You have a 4l60 but that is just a renamed 700R4. Same trans. The page I posted is from my 92 FSM.
Old Jan 26, 2018 | 10:34 AM
Brenden Schaeffer
A few cities a way there is a local shop selling rebuilt transmissions with a 1 year warrenty for 650$. What do you guys think?
Old Jan 26, 2018 | 10:43 AM
BlowerWorks
Supporting Vendor
Hey Guy ! Changing trans fluid to Amsoil SuperShift probably won't fix but it might ! It's a "cheap" fix that just might work ? Be really fun to hear you report back after so doing ? Drop the trans pan and clean, change filter, and use AMSOIL SUPERSHIFT !!!!! You might be surprised ! greg
Old Jan 26, 2018 | 11:44 AM
arbee's Avatar
arbee
Interesting you would recommend this fluid. Below is a direct quote from the Amsoil website.
Note: AMSOIL Super Shift Synthetic Racing Transmission Fluid is not recommended as a replacement for Ford MERCON*, GM* DEXRON or Chrysler* ATF+ type fluids in passenger vehicle and truck transmissions as it may cause erratic shift patterns, chattering or noise.
Old Jan 26, 2018 | 12:07 PM
383vett's Avatar
383vett
I use Amsoil Super Shift in my bracket car 4l60e with good results. Again, this is not a street car.
Old Jan 26, 2018 | 12:09 PM
arbee's Avatar
arbee
It is probably an excellent product for it's intended usage.
Old Jan 26, 2018 | 03:18 PM
arbee's Avatar
arbee
I have no idea how far you are from a major centre but my advice would be to do some research and try and find a shop that has some good feedback. If you are lucky, one will throw a gauge on and check your pressures and do a bit of diagnostic work and give you your options. Transmissions are more complex than an engine and can have many reasons for not operating properly. Unless you have the desire and ability to rework it yourself, you are at the mercy of the shop you are dealing with.
To Transmission shift weird
Old Jan 27, 2018 | 07:28 AM
BlowerWorks
Supporting Vendor
Hi Arbee !!! Regardless of what Amsoil says I have used 'SuperShift' in several of my cars as well as many 700R4's. Remember that fluids like Dexron have friction modifiers designed to enable slip for smoother shifts.
I aslo recommend 'SuperShift' for all Paxton ball drive owners (SN-etc.).
I also own a 98 Neon and run 'SuperShift' in it !!!!!!!!
So all I can say is I love 'SuperShift' - especially in older vehicles.
And in this case what's to lose - what if it does work? And if it doesn't he tears down a cleaner trans ....... greg
Old Jan 27, 2018 | 10:15 AM
arbee's Avatar
arbee
I somehow figured you would come back here and despite factual documentation even from the manufacturer of the product
and make a claim that your way is right way and nobody is going to tell you different. I have a sneaking suspicion that you were the prototype for the Kentucky mule. Carry on.
Old Jan 27, 2018 | 10:18 AM
RF1's Avatar
RF1
There you go.
Thread over.
