ZR1 Engine
Old Jan 28, 2018 | 12:02 PM
oVoSanto's Avatar
oVoSanto
Default ZR1 Engine
Hi all, the ZR1 engine has known problems? It consumes a huge quantity of lubricant right? Do you recommend it for an hot rod with T56 gear box?
Old Jan 28, 2018 | 12:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
pretty reliable, but wont be cheap when you need to find parts and have them shipped. Are you using aftermarket EFI & fuel system?. They hold quite a bit of oil-
Would it be cool, sure but not cheap and easy.
Old Jan 28, 2018 | 12:27 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
I have a 95 ZR-1. The engine is bullet prof. Mine doesn't use oil if that's what you're asking. It holds 9 quarts of oil. Parts are easy to get at Jerry's Gaskets.com Anything you need except new ECM.
Old Jan 28, 2018 | 03:14 PM
oVoSanto's Avatar
oVoSanto
I will use the standard ecu and wiring
Old Jan 28, 2018 | 05:07 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
That's a new one, The early LT5s may have burned a bit as no exhaust valve seals, huge quantity HAHA
Old Jan 29, 2018 | 03:11 PM
vettehardt's Avatar
vettehardt
Yea, the 90-92 motors used some oil because they don't have valve seals. But it isn't very much (1/2 quart max between oil changes), and it just gets blown out the exhaust. When they redesigned the heads in 93, they added valve seals.
My dad's 90 did develop a leak, but it was the oil pressure sensor that caused it. He replaced it and no issues since.
Actually the motors hold 11 quarts of oil, but when doing an oil change, you will only get 9 quarts out (and only put 9 quarts back in). This is due to the design of the motor there are places where the oil will not drain back to the pan.
As for being in a hot rod, there shouldn't be an issue as long as you can find a bell housing to bolt the T56 to the motor. The motors are bulletproof and there are quite a few here in the states with 150,000+ miles on them. The only downside, is there really isn't anybody around willing to work on them any more.
Old Jan 29, 2018 | 03:38 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
The other two quarts of oil are in the oil cooler sandwiched between the radiator and AC condenser yes it is large! The fittings on the lines from the motor to the cooler were also redesigned as the could leak on the 90-92 cars.
To ZR1 Engine
