93 Coupe - Interior Lights/door ajar buzzer
Old Oct 12, 2002 | 08:45 PM
lmac2's Avatar
lmac2
Default 93 Coupe - Interior Lights/door ajar buzzer
The courtesy lights don't work at any time in my vette. The door ajar buzzer however, is constantly once the alarm is disarmed and the doors unlocked. If the ignition key is placed in the run position it ceases, or interestingly enough, if the hatch is raised. Any advise would be greatly apprecaited. :confused:
Old Oct 13, 2002 | 01:38 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 93 Coupe - Interior Lights/door ajar buzzer (lmac2)
If you hear a buzzing sound and your lights don't work, it's a blown fuse.
Same thing happened in my '93.
The buzzing was there to warn me that the fuse was blown.
There are two, a 5 and a 20, the 20 also ties in with the radio.
Old Oct 13, 2002 | 02:45 PM
lmac2's Avatar
lmac2
Default Re: 93 Coupe - Interior Lights/door ajar buzzer (Mr Mojo)
Tnaks for the tip. I solved the buzzer problem, by ensuring that the manual key locks were in their proper position. Now I just have to solve the lights. Thanks a real lot. :)
Old Oct 13, 2002 | 05:25 PM
lmac2's Avatar
lmac2
I just purchased the 5 amp fuse, replaced it and problem solved.
Thanks again. :chevy
To 93 Coupe - Interior Lights/door ajar buzzer
