heater core
Old Jan 30, 2018 | 10:25 AM
pnewt's Avatar
pnewt
Default heater core
Every where I read, I see changing out the heater core is a real pain in the A.... Mine has been bypassed and speaking to the original owner, he had it bypassed due to a leak. The hoses have plugs in them Not a big deal to leave as is, but can someone give me an idea what a shop would charge to do it? Cant be cheap Thanks Car is 92
Old Jan 30, 2018 | 10:32 AM
ddahlgren's Avatar
ddahlgren
Call a dealer to get flat rate time. I am betting 8 hours or so. BTW the words 'heater core' are very close to foul language.
Old Jan 30, 2018 | 10:35 AM
pnewt's Avatar
pnewt
Default core
might be better to wear 2 coats instead!! thanks
Old Jan 30, 2018 | 12:00 PM
ddahlgren's Avatar
ddahlgren
Old Jan 30, 2018 | 01:03 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I had this done about 10 years ago at a corvette specialty shop. Charged me 7 hours of labor. The heater core itself is not very expensive.
Old Jan 30, 2018 | 01:13 PM
pnewt's Avatar
pnewt
Default core
got estimate from local dealer $300
Old Jan 30, 2018 | 02:00 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
If you can get a 92 done at the dealer for 300, TAKE IT NOW.
There are different schools of thought on a 92 with the biggest issue being to remove the dash or not. There are several "hidden" tough to get a screws that making dash removal attractive.
The estimates on time that I see are in the 8-10 hours and these are from professional shops.
Old Jan 30, 2018 | 02:10 PM
pnewt's Avatar
pnewt
Default core
service writer is a friend and big Corvette guy, he knows whats necessary so I'll probably go that route. he used to be major player at Keen Parts thanks
Old Jan 30, 2018 | 02:44 PM
ddahlgren's Avatar
ddahlgren
Break the speed limit as much as needed to sign off on that quote. Let the provide the heater core too so if problems it is their problem.
Old Jan 30, 2018 | 08:12 PM
billschroeder5842
Please see if the service writer/dealer will honor the 300 bucks as a CF deal.
If the 300 is the real number, I will make the trip as preventative maintenance for the core swap.
Old Jan 30, 2018 | 08:19 PM
aklim's Avatar
aklim
But you also want to blow hot air on the glass if it mists up unless you want to drive with the top off or a periscope
Old Jan 30, 2018 | 09:02 PM
pnewt's Avatar
pnewt
Default heat
no I'd just stick my head up over the truss bar!
Old Jan 30, 2018 | 10:24 PM
aklim's Avatar
aklim
Suit yourself but it would look so cool with a periscope.
Old Jan 30, 2018 | 11:33 PM
Lazy Tom's Avatar
Lazy Tom
It's cold without a heater.
Old Jan 31, 2018 | 09:34 AM
ctmccloskey's Avatar
ctmccloskey
For $300 I would get mine done as well. Mine has not leaked as of yet but time passes on.
Here in the Northern Virginia area Dealers are charging $150 for a parts replacer. The gas stations mechanics are now up to $125 per hour.
Good Luck and change the anti-freeze frequently so your Heater core doesn't corrode out so quickly.
Old Jan 31, 2018 | 11:30 AM
ghoastrider1's Avatar
ghoastrider1
Foul words indeed, Plese , never say those words again
To heater core
