c4 headlamp not acuating
Old Feb 3, 2018 | 12:19 PM
ahoyt71's Avatar
ahoyt71
2nd Gear
Default c4 headlamp not acuating
my head lights come on but only one flips up then when turned off lights go out but no movement
Old Feb 3, 2018 | 02:29 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
You need a new headlight motor. Common problem.
Old Feb 3, 2018 | 02:59 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Bill, you can do better than that! We don't even know what year Corvette the guy has. The problem may be a very simple fix, but we need to start with more basic information.
Yes, this is a common problem, and the answer might even be found with a search in the "Sticky" section at the top of this page.
Old Feb 3, 2018 | 03:11 PM
ahoyt71's Avatar
ahoyt71
2nd Gear
87 model
not really good with electrical tracking but i am a quick study
Old Feb 3, 2018 | 06:47 PM
Hot Rod Roy
Post #16 in the "Sticky" section will help in repairing your headlight motor, but your problem shouldn't need any new parts! The most likely problem is dirty limit switches on the motor shaft. This link doesn't spend much time talking about the limit switches, but the procedure for opening the motor is good.
https://www.corvetteforum.com/forums...placement.html
Please complete the information in your personal info section. It makes it a lot easier to get you on the right track! Welcome to the Forum!
To c4 headlamp not acuating
