Question on setting oil pump pickup clearance...
Old Oct 13, 2002 | 07:52 PM
Rich B.'s Avatar
Rich B.
Default Question on setting oil pump pickup clearance...
How do *you* determine how far from the bottom of the pan to tack it in place???
Leave it loose and let the pan "push" it up in place???
Tape a shim of some kind to it & push pan against it???
Carpenters rule & eyeballs???
Old Oct 13, 2002 | 08:05 PM
dtorc4's Avatar
dtorc4
Default Re: Question on setting oil pump pickup clearance... (Rich B.)
My book, "How to build the small block Chevy" says to let the pan push the pickup down, then remove the pan and push it 1/4" in the same direction. This is what I did and had it tack welded into place.
Old Oct 13, 2002 | 08:13 PM
scorp508's Avatar
scorp508
Installed parallel to the oilpan rails I found that the pickup would be about 7/16" off the oilpan bottom. I installed mine in this position.
Old Oct 13, 2002 | 09:48 PM
RichS's Avatar
RichS
Default Re: Question on setting oil pump pickup clearance... (dtorc4)
This is what I always do.
To Question on setting oil pump pickup clearance...
