1.6 roller rockers
Old Oct 13, 2002 | 09:58 PM
94-LT1's Avatar
94-LT1
Default 1.6 roller rockers
I was debating on putting 1.6 rockers on my 94. only mods i have are exhaust and mass air sensor. would the rockers help any or is this not a good idea right now.
Old Oct 13, 2002 | 10:04 PM
STL94LT1's Avatar
STL94LT1
Default Re: 1.6 roller rockers (94-LT1)
I have Crane Gold 1.6 roller rockers on my 94, and they really make the car rev smoother, especially above 5000 rpms.
Old Oct 13, 2002 | 10:29 PM
vader86's Avatar
vader86
yes, its a good idea, and youll probably get 10-15hp from it
Old Oct 13, 2002 | 10:31 PM
Jay Axson's Avatar
Jay Axson
Go for it, make sure you replace the springs too. I read of 10 -15 hp gains.
Old Oct 14, 2002 | 11:21 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
With stock cam....will increase HP slighty...can't hurt....worth it....do you have the top end disasembled???
Then go for it......check clearance on valve covers...for oil drain back...should be OK..... :cheers:
Old Oct 14, 2002 | 11:26 PM
Carnivore's Avatar
Carnivore
Default Re: 1.6 roller rockers (oldace84)
How do you check the clearance from roller rocker to value cover?
Old Oct 15, 2002 | 12:31 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
Default Re: 1.6 roller rockers (Carnivore)
its worth it. Get nw valve springs while your at it. Dont get the lt4 springs, theyre not needed and willrob approx.5-10 horse cuz of the extra pressure. Stick with the stock replacements. Guaranteed higher revving ability + smoothness.
Old Oct 15, 2002 | 02:19 PM
88-L98-Z52's Avatar
88-L98-Z52
Default Re: 1.6 roller rockers (388 SOLid RoLLeR)
Darn... now I'm confused... I've always heard that when switching to 1.6 rockers, that it was recommended to also switch to LT4 springs because they could handle the extra stress better than the stock springs....
Old Oct 15, 2002 | 03:06 PM
STL94LT1's Avatar
STL94LT1
Default Re: 1.6 roller rockers (88-L98-Z52)
With stock springs and 1.6 ratio rockers you will be very close to valve float, you should upgrade your valve springs just to be safe.
Old Oct 16, 2002 | 07:10 PM
blk95's Avatar
blk95
What the deal? New stock valve springs or the LT4 springs
Old Oct 16, 2002 | 07:38 PM
silver & red CE's Avatar
silver & red CE
Default Re: 1.6 roller rockers (blk95)
Go with the LT4 springs, the stock springs are within 0.020" of crush with 1.6 rockers and the stock cam. You won't lose any HP from them, they are very light, ~240# closed.
Eric
To 1.6 roller rockers
