1987 corvette shut off
Old Feb 15, 2018 | 09:59 PM
Martin082514's Avatar
Martin082514
Cruising
Default 1987 corvette shut off
Hello I need help my 1987 corvette just shut off on me while driving on the freeway everything else worked but the motor just turned off on me gauges and cluster were still on I'm about to change the starter on it because when I tried to start it it would make a nasty grinding noise but what I want to know is why did the engine just shut off on me though so that it doesn't happen again?
Old Feb 15, 2018 | 10:32 PM
C409's Avatar
C409
..... Do the basic troubleshooting ... Fuel , Air , and Fire at the right time in the right quantities = running engine ... look for spark , check fuel pressure , clear the coyote from the intake , and make sure that there are no rods hanging out of the side of the block ! .....
Old Feb 16, 2018 | 06:57 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Must be close to a record. 79 words in one sentence.
Old Feb 16, 2018 | 01:43 PM
ctmccloskey's Avatar
ctmccloskey
With the engine having shut down on the freeway is it correct to assume that the car is someplace where you can work on it now?
Are you fairly competent at working on your Corvette? How long have you owned it? What happened that led up to the engine shutting off on the highway?
Do you possess the tools needed to check your fuel pressure on the fuel rail at the Schroeder valve on the passenger side near the rear of the plenum? Has the car had any issues lately PRIOR to the highway problem? Longer than normal cranking, anything?
When does the the starter make this "Grinding noise" all the time, once in a while or only after the highway event?
Is the car a manual or an automatic?
Does the engine turn over now that it has cooled off?
Did you get any codes or check engine lights when the problem happened?
What does the oil look like? Is there enough of it? How about coolant?
It would really help us if we have as much information about this car as possible for us to be able to help you. Answer the questions above and we can make some headway hopefully!
Good Luck and lets help you figure out what is happening with your 1987!
Old Mar 17, 2018 | 03:01 PM
waddiejohn's Avatar
waddiejohn
Vats???
Old Mar 19, 2018 | 11:53 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Originally Posted by waddiejohn
Vats???
The security system, VATS, does get flaky eventually, all too often. Pretty sure it will shutdown ignition if tripped, among other things.
There are a few methods to deal with it, search the forums.
To 1987 corvette shut off
