Should be bolt and go. My FSM half shows an 84 and half shows an 82. The 84 intake may have holes between the runners the 82 doesn't. Maybe a different part number for the injectors. It'll work fine. Or at least from my understanding it should.
One caution (you may know) the front and rear injectors are of different capacity, supposedly to make up for the fuel pressure drop in the system. The Camaro 305 Cross-Fire has yet another set of lower capacity injectors.
I'm not sure on the fuel presure thing, but the front injector hold the IAC valve and the rear does not.
the 1st # is the front rated at 67lbs/hr the 2nd # is rear rated at 68lbs/hr
