Turn signal help
Old Feb 24, 2018 | 12:01 AM
JBJrC4's Avatar
JBJrC4
Default Turn signal help
I have a 91 Corvette. I'm only able to signal to the left, but when I try to shift to the right the lever simply goes up without doing anything. I looked into it and noticed a bracket with two screws that's on the turn signal switch that goes on the wiper switch. It seems that the bracket has a small silver object that slides off the wiper switch causing it to not signal. Is this a turn signal switch problem or a wiper switch? Thanks.
Old Feb 24, 2018 | 11:20 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Without much information, my guess is that it neither a wiper or turn signal probmen, but a stalk problem; the whole unit is integrated.
I'd take it off, clean it, look for obvious problems, fix and replace.
