c4
Old Feb 28, 2018 | 08:52 PM
rookie 84's Avatar
rookie 84
7th Gear
Default c4
i have 84 vet put factory radio in and anew battery now wont start turn key and get nothing no click nothing thanks
Old Mar 1, 2018 | 02:53 PM
DGXR's Avatar
DGXR
Turn off radio, or disconnect radio completely from wiring. Check fuses. Check battery connections. report back.
Old Mar 1, 2018 | 04:55 PM
rookie 84's Avatar
rookie 84
7th Gear
Default c4
dissconnected radio fuses are good battery is new and connections are clean and tight. one more thing ign key gets real hard to turn when it is athe end almost have to use two hands to turn thank you so much for any advice
Old Mar 1, 2018 | 05:45 PM
DGXR's Avatar
DGXR
This thing about the key being hard to turn, is that new?
Hard to believe a new radio broke the ignition cylinder or the ignition switch... do these cars have an ignition switch?. Anyway, even if you left the ignition on to supply power during radio installation, it should still be OK. Not sure what to say. Hope other will chime in. Good luck.
Old Mar 1, 2018 | 06:13 PM
rookie 84's Avatar
rookie 84
7th Gear
i have had the car for about 6 months and key was hard to turn when i bought it . dont know if radio install has anything to do with the no start may be just a coinsadence . have to turn key way far forward to start . dont seem normal to me . would like know how check lock cylinder and ign or how to bypass thanks
Old Mar 1, 2018 | 06:44 PM
s carter's Avatar
s carter
There is a Ignition switch on the lower Steering Colume that is your main Power Distribution source, If is gummed up/Burned out could be your High Effort Luckily they are cheap and common at parts store.
You could start by pulling it and see if the Effort in turning of the key goes away. and with the switch in hand do some testing.
If there a problem with the Ignition Cylinder and the slide rod it to is Cheap again about 15/20 Dollars being a Non-Vat's System
Old Mar 3, 2018 | 09:02 PM
rookie 84's Avatar
rookie 84
7th Gear
problem solved vats bypass worked starts fine thanks everyone for there help
Old Mar 3, 2018 | 09:48 PM
Hot Rod Roy's Avatar
Hot Rod Roy
VATS in an '84? I don't think so!
Old Mar 3, 2018 | 09:53 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Some trick that would be
To c4
