Issues changing washer pump
Old Mar 3, 2018 | 06:36 PM
MarkItZero's Avatar
MarkItZero
Default Issues changing washer pump
My car is a 92 with an automatic. Since purchasing it last month the washer has never worked. Set out last night and today to change the pump. After a few missteps I got all the body panels off and got to the washer. When pulling the line off the pump (pet another thread) I realized it appears to have been cut and was just ending at a random location under the hood. Now what exactly is the name of this part so I can get another one? And even more importantly where does the other end of the line go? Where exactly does the splash spray out off? It doesn't appear to have nozzles on the hood, so I'm guessing it sprays out the wiper arms?
here's what came off my washer pump:
Sorry for the rambling post I'm just exhausted and using my phone vs pc.
Old Mar 3, 2018 | 07:31 PM
valiant68's Avatar
valiant68
Sorry i cant answer your question, i also have a 92 automatic with the same problem, but i have a leaking resovoir, that needs to be changed, maybe someone will chime in with advise.
Old Mar 3, 2018 | 07:49 PM
MarkItZero's Avatar
MarkItZero
If you're just changing the reservoir it's not so bad. Just put the front up on stands and pop the hood. Do that and then follow this thread: https://www.corvetteforum.com/forums...luid-pump.html
Old Mar 3, 2018 | 08:15 PM
valiant68's Avatar
valiant68
Thank You, that is a very helpful thread.
Old Mar 4, 2018 | 10:57 AM
MarkItZero's Avatar
MarkItZero
So no one knows where to connect this line to?
Old Mar 4, 2018 | 11:25 AM
s carter's Avatar
s carter
Without overthinking it I took a look at my 93 to confirm, it's just a Hose from the Bottle/Pump to the Passenger Vent well near the Bottom of windshield, Ties into a 3 way hose connector. Then 1 hose goes to L. Arm 1 Goes to the R. Arm
Old Mar 4, 2018 | 01:49 PM
MarkItZero's Avatar
MarkItZero
thanks I was able to find it.
Old Mar 4, 2018 | 11:03 PM
NASCAR314's Avatar
NASCAR314
Be careful, I had same issue, thought it was a leaking reservoir, turned out it was the actual pump housing was leaking. This was in a 96, pump is down low on tank.
Ended up replacing the tank and pump to fix the problem.
Old Mar 5, 2018 | 02:00 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you need a reservoir/pump, I've got one.
To Issues changing washer pump
