Smoke Cloud From Exhaust
Old Mar 6, 2018 | 09:54 AM
Tristanatorvettes's Avatar
Tristanatorvettes
4th Gear
Default Smoke Cloud From Exhaust
Hey guys,
Thinking of buying a C4 next week, and I've heard of the issue of a smoke cloud coming out of the exhaust upon starting the car after it's been sitting for a few hours and lasting for 30 seconds or so. Anyone experienced this, and if so is it a major problem?
Old Mar 6, 2018 | 10:19 AM
fredk's Avatar
fredk
Is it white or black ??
Old Mar 6, 2018 | 10:33 AM
Kevova's Avatar
Kevova
White most likely condensation no worries. But make sure cooling system isn't losing coolant.
Blue valve seals and/or guides worn.
Black over fuel leaking injector(s) or FPR. Sensor skewd.
Old Mar 6, 2018 | 12:18 PM
DGXR's Avatar
DGXR
First I would not say smoking exhaust is common for C4 Corvettes.
Condensation/steam from the exhaust is normal and nearly every car does this on cold mornings. This is not smoke and it usually disappears within a few minutes. It sounds like this is what your car is doing -- if everything else works fine and the car runs good, I would not worry about it.
But Kevova is right that steam can also be caused by bad head gasket - coolant entering the combustion chamber (loss of coolant).
If you are talking about actual white smoke (not steam) that happens only on startup, again Kevova is right that it's valve guides or valve guide seals. This usually happens on motors with high-mileage or have excess wear for some reason (abuse, lack of maintenance, etc). If it's really smoke and it happens all the time, that's probably worn piston rings.
Black smoke is caused by excess fuel or heavy detonation (during acceleration).
Old Mar 6, 2018 | 01:34 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
my 87 puffs a nice cloud on starup and its valve seals. very easy diy job and is fun. requires a few specialized tools.
Old Mar 7, 2018 | 01:22 PM
Tristanatorvettes
4th Gear
Thanks for all the info guys!
To Smoke Cloud From Exhaust
