C4 Power Window Troubleshooting
Old Mar 7, 2018 | 02:57 PM
quadracerx's Avatar
quadracerx
Default C4 Power Window Troubleshooting
Hey Guys,
On to the next project...
My power windows quit working (both sides), I looked at the fuse panel and there is a "relay" instead of a fuse? Do these reset themselves? Can you buy new?
The windows just quit working one day, so I figured it was a fuse...
Is there a Troubleshooting Guide of some kind...?
Thanks for the help...
Steve
Old Mar 8, 2018 | 03:39 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
When flipping a window switch, do you hear any noise at all in the door?
I'd think relay too, but I had two windows motor fail about the same time, the glue holding the magnets in place (!?!?!) got old and let go.
Old Mar 8, 2018 | 07:31 PM
quadracerx's Avatar
quadracerx
I hear no noise with either side...
Do these relays reset themselves or can you buy new ones?
Thanks,
Steve
Old Mar 9, 2018 | 02:21 AM
Hot Rod Roy's Avatar
Hot Rod Roy
I'm presuming this is a question about your '84. It's always a good idea to tell us what you're working on, so we don't have to research your previous questions. This info should also be in your personal profile.
There are no relays in the power window circuit. If both windows failed at the same time, it's likely to be a circuit breaker failure, or a bad ground. The circuit breaker can be pulled from the fuse panel and tested just like a fuse (with an ohm meter/DVM). The ground connection is on the RH door hinge pillar, behind the "bread box".
To C4 Power Window Troubleshooting
