Got a problem with my 95 supercharged LT1. the car starts up fine, I put a few miles on it to fully warm up and out of nowhere the car just stalls out. I try to start it,it cranks but wont start. wait about a hour and it will start but Ill go a mile or two and it stall out again. The first tow truck driver said it sounds like a fuel pump problem, so I replaced the fuel pump,same thing happened so its not the pump what else could it be. Anybody else have this happen
optispark I hear there a bitch to replace I think that why you said sorry. Ill check it out thanks brother.
Ok so I changed the fuel pump, ignition module, and coil, no good, car still stalls. So now Im going to change the optispark and the crank trigger module. I seen a video on it and its a nightmare to change. I thought the crank trigger was in the same area but there was no mention of it when the guy was taking every think apart. Anybody know where the crank trigger is located
Due to the $$ and the hassle involved, the opti-spark is something that you want to diagnose as being the problem before you go throwing one at the car to see if "that part" was the problem.
Are you able to pull any codes?
I know you changed out the fuel pump. Did you replace the two relays?
Any way to rig a fuel pressure gauge so that you can see the fuel pressure when it stalls?
Did you put the supercharger system in or was it there when you bought the car?
Thanks for helping out, No I didn't replace any relays on the pump. I have a fuel pressure gauge in the car but I never think to look at it when it stalls cause I looking out where to pull over. After it stalled today I called a friend of mine he came down with a spark plug tester and it had spark but it is weird because in the past the car wont start again until it cooled off for a hour or two. But today he pulled the #4 cylinder boot off and when he put it back on it started. So Im confused as what can be causeing this. And when I brought it it was surpercharged. Thanks again for helping out today
