1990 Transmission sump bolt sheared
Old Mar 16, 2018 | 06:12 PM
Tony Trans Am's Avatar
Tony Trans Am
Default 1990 Transmission sump bolt sheared
1990 Transmission sump bolt sheared, when changing filter and fluid. Any suggestions on how to remove it? Also where can I get a replacement bolt and what size is it?
Old Mar 16, 2018 | 06:53 PM
WVZR-1's Avatar
WVZR-1
Bolt is M8x1.25x20 - the OE is pretty damn hard. The head should be maybe marked 9.8. Is it in one of the locations that's a pass through and easily accessible top of the pan rail? Most are. Original would have a captive 'free spinning conical' washer on it.
Should be easily sourced. Correct GM is likely expensive. Visit a shop!
Old Mar 16, 2018 | 07:06 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
First, spray it with PB. Then put some ATF/acetone mix on it. Then melt a candle on it. Then do a ritualistic dance....
Just kidding. Go right to what works; get a MIG welder, clean it up good, weld a nut onto what's left of the bolt....remove.
Old Mar 17, 2018 | 01:18 PM
383vett's Avatar
383vett
There were millions of these trannys made over the years. Any tranny shop will have a bunch of these bolts lying around. Bring one of your good bolts to a tranny shop and they should give you a bolt or at most charge you a buck or two. If you're in the Bay Area, I've got a bunch of them.
To 1990 Transmission sump bolt sheared
