Brake pedal is hard
Old Oct 15, 2002 | 01:26 PM
Kehrer923's Avatar
Kehrer923
Default Brake pedal is hard
what would cause me\y pedal to be hard ? all vacum lines are still connected etc...
Old Oct 15, 2002 | 01:36 PM
ELEVENS's Avatar
ELEVENS
Default Re: Brake pedal is hard (Kehrer923)
Oh oh. Sounds like your vacuum booster isn't working.
1) It's under the hood, on the driver's side. Check to see if the vacuum line (about a 1/2" black hose) is securely connected to it.
2) If #1 OK, then borrow or buy a small hand-held vacuum pump w/guage, hook it up to the booster, pump it up, and see it it "holds".
If it's the booster, you're out a couple hundred bucks. They're not too bad to replace, except for the two bolts inside the car under the dash are a little hard to get at. Don't be tempted to buy a cheap booster at your local parts store, I've tried two, each lasting a couple months longer than the 1 year warranty. The genuine GM one from the dealer is the way to go, in my opinion.
Good lucK!
Old Oct 15, 2002 | 01:58 PM
vader86's Avatar
vader86
bad brake booster
Old Oct 15, 2002 | 02:10 PM
maize's Avatar
maize
Please, define "hard." Is it so hard that it is difficult to drive the car, or actually annoying. My brake pedal has always been much more firm than my buddies '95, but I didn't think that there was a problem.
Old Oct 15, 2002 | 02:12 PM
maize's Avatar
maize
Default Re: Brake pedal is hard (ELEVENS)
When you say pump up the vacuum pump ... how much vacuum should it hold?
Old Oct 15, 2002 | 10:00 PM
Kehrer923's Avatar
Kehrer923
Default Re: Brake pedal is hard (maize)
like pedal being hard as it is rock hard to push down, during everydaydriving
To Brake pedal is hard
