1992 c4 ac/heater programmer location
Old Mar 17, 2018 | 04:20 PM
jmk1938's Avatar
jmk1938
Cruising
Default 1992 c4 ac/heater programmer location
1992 corvette c4;where is the ac/heater programmer physically located.It is sending a solid 6volts to the blower module causing the blower to run full speed.
Old Mar 22, 2018 | 08:42 AM
DykstraMotorsports's Avatar
DykstraMotorsports
I believe it is above the gas pedal.
Old Mar 22, 2018 | 09:47 AM
jmk1938's Avatar
jmk1938
Cruising
Yes, thank you. I found the fuse located behind the cooling water tank on the right side on the firewall to be my problem.
To 1992 c4 ac/heater programmer location
