U-Joint replacement
Old Oct 15, 2002 | 02:03 PM
Crispyc21's Avatar
Crispyc21
Default U-Joint replacement
I get the 'clunk' noise coming from the back of my car. I think it’s the same one a lot of people have here on the forum. Most say its the U-joints, so now I'm looking to replace them. Is this expensive to do? Is this something that someone with basic car knowledge can do with a buddy or two helping? I will be replacing my rear bearings soon and wondering if I should do both at the same time.
Old Oct 15, 2002 | 02:04 PM
scorp508's Avatar
scorp508
Let me introduce you to a little friend of mine...... http://personal.tmlp.com/scorp/vette/images/ujoints/
Old Oct 15, 2002 | 03:17 PM
Ender85's Avatar
Ender85
Default Re: (scorp508)
excellent :cheers:
Old Oct 15, 2002 | 04:25 PM
Crispyc21's Avatar
Crispyc21
Awesome directions...Thanks
Old Oct 15, 2002 | 05:11 PM
Paul G's Avatar
Paul G
Just read through this link. Great info.
Is it possible to have bad U-joints even if you cant feel any looseness in them when you try to wiggle them around?
Old Oct 15, 2002 | 05:29 PM
Grzldvt's Avatar
Grzldvt
Default Re: (Paul G)
Yes,
Mine felt solid, with the car on the ground, or off the ground and was clunking and grinding. I could not see any sloppiness. Once I got one of u-joints off, it fell apart in my hand.
I have done both sides, one was when I replaced the wheel bearing, which made the bearing replacement much easier, and the other with the bearing in, following scorp's instructions.
Old Oct 15, 2002 | 06:11 PM
brookman's Avatar
brookman
awesome documentation!
Old Oct 15, 2002 | 06:31 PM
dlmeyers's Avatar
dlmeyers
Default Re: (brookman)
Remeber too some parts stores have the nice u-joint press tool for rent or free use. Makes things go much smoother, than say, a big hammer.
Also, some drive shaft places will do bench work at a very reasonable cost. The main expense is removing and replacing the shafts.
Good luck with your work.
dlmeyers 90 coupe zf6 3 speed shocks
Old Oct 15, 2002 | 07:25 PM
Mike's 86's Avatar
Mike's 86
Good job on the pics. :cheers:
Old Oct 15, 2002 | 07:31 PM
90Z51Vette's Avatar
90Z51Vette
Default Re: (dlmeyers)
I found a local truck drive shaft shop that pressed mine for $20. Only took them a few minutes. The hammer/socket method is risky and can end up being $$$ if you screw up.
Good luck,
Mark
:cheers:
To U-Joint replacement
