Best performance upgrade Combo
Old Mar 21, 2018 | 06:42 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Default Best performance upgrade Combo
Ok is this the best combination for my 91 stock (700r4):
- Edelbrock Pro-Flo XT
- Edelbrock Fuel Rails
- Edelbrock TB (90mm)
- Lingenfelter Cam 219
- AFR Heads 180 or 195cc (or??)
- 1.6 RR
- Torque Convertor 2500
- Hooker Headers (2149) -Y pipe 16720
- Borla Exhaust (3”) no cats
and if it is what would be the gain, will that get me to 350+ rwhp? And where to start first top or bottom?
TIA
Old Mar 21, 2018 | 11:28 AM
vader86's Avatar
vader86
I haven't seen a ton of dyno results on the Pro-Flo, but it looks like a Holley StealthRam so it should be similar.
This engine will remain a 350ci? I could see you getting to your goal. If I remained a 350 and intended to stay there, I might stick with the AFR 180, but I personally chose the 195. It will also allow you to keep the same heads should you go 383 or larger someday.
Old Mar 22, 2018 | 05:10 PM
C409's Avatar
C409
..... I don't believe that the Pro Flow with a Throttle Body will fit under a stock Corvette hood ... I'm sure if any CF members know differently they will chime in .....
To Best performance upgrade Combo
