Heater core question
Old Mar 22, 2018 | 01:41 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default Heater core question
Replacing the heater core on my 94, which as you may know is a delight, and this plastic piece appeared on the floor when I got the case apart. Can someone tell me exactly where it goes? It's bad enough I probably won't remember where some of the nuts and bolts scattered around the floor go...
Old Mar 22, 2018 | 07:49 PM
WVZR-1's Avatar
WVZR-1
Turn it over and see if there's a part# molded into it!!
Post that number - I'd think you'll find one.
Old Mar 22, 2018 | 08:15 PM
belairbrian's Avatar
belairbrian
The housing has a hole in it that is covered by a tube running from top to bottom on the heater core housing. It goes in the hole.
Old Mar 22, 2018 | 09:24 PM
POLOVETTE 94
Oh, the tube that runs across the case, and has two screws that hold it to the case? I guess all the yanking to get the tube away from the case caused the piece to fall off, and into the case. So, how am I supposed to put it on the tube, if I can't pull the tube far away enough from the case?
Old Mar 22, 2018 | 09:46 PM
belairbrian
Yes, it goes behind that pipe. The pipe comes up from the left, turns horizontal then turns up to the right at about a 45 degree angle. That duct goes to the side window defroster on the right.
How far apart do you have the dash? When I did mine I followed the FSM so I had everything out of the way.
Old Mar 22, 2018 | 10:07 PM
POLOVETTE 94
Old Mar 22, 2018 | 11:15 PM
belairbrian
In the first picture I can see the 2 ducts that tube connects too. The tube looks to be out.
The second looks like the Air bag is back in. Might have to remove the airbag to get the tube out.
Old Mar 23, 2018 | 06:07 AM
POLOVETTE 94
The second pic was actually taken first, the airbag is still out. The tube is disconnected from the defroster tube on the right, but I couldn't get it off where it goes behind the radio on the left. Does it just pull out of there?
Old Mar 23, 2018 | 09:55 AM
belairbrian
No I think the tube goes all the way across. When I did mine I had a lot more removed. Look at post #51 in this thread. With the relay mount and harness down and out of the way there is more room to move the duct.
https://www.corvetteforum.com/forums...post1594756404
Old Mar 25, 2018 | 07:05 PM
POLOVETTE 94
Ok, got the new core in. Question...should I apply some sort of sealant between the two halves of the case? It looks like some black silicone was at least across the bottom when I pulled it apart.
Old Mar 26, 2018 | 08:28 PM
belairbrian
Wanted a chance to check the FSM before I answered. I knew mine didn't have any and there is no mention of sealant in the assembly instructions.
Best guess is it was added to stop a leaking core from dripping.
Old Mar 27, 2018 | 08:27 AM
POLOVETTE 94
Well that would explain the green coloring on the inside of the case. I'm glad it never got worse. Funny thing is.. I have had the car for 20 years, I got it when it was less than 4 years old, with just under 38,000 miles. So...it is likely that the silicone was a shortcut at the dealer for a warranty repair.
Old Mar 28, 2018 | 07:34 AM
JasBass's Avatar
JasBass
Always a joy finding those hidden dealer fixes... I agree with everyone above. It looks like part that little hose that attaches to the main housing and carries air to your door defrosts. Replaced the heater core in my 89 a few months back, I did the same thing when putting parts back, like a jigsaw puzzle.
Old Apr 1, 2018 | 12:19 PM
POLOVETTE 94
Trying to get things buttoned up. I can't seem to see or remember where this was clipped to. It doesn't connect to anything, but I wanted to clip it back in the same location.
Old Apr 1, 2018 | 12:44 PM
WVZR-1's Avatar
WVZR-1
See the FSM 8A-201-20 'Door Ajar Indicator Module' - wire colors seem to match.
Was there a number molded into that duct from a very early post?
To Heater core question
