Rocker arms
Old Mar 27, 2018 | 12:30 PM
design god's Avatar
design god
Default Rocker arms
Has anyone ever replaced there rocker arms on a 96 lt1 motor?
I want to replace my valve seals so i thought i woud put lt4 springs along with 1.6 rocker arms.
Has anyone done this to their lt1 motor?
Design god
Old Mar 27, 2018 | 12:45 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Welcome to the forum. The answer to your question is Yes. Many people have done this to late modle LT1 engines.
As long as you're in there doing that.... why not consider the LT4 Hot Cam Kit for your LT1. The kit comes with 1.6 roller rockers, matched springs & retainers as well as the hot cam itself.
This is actually an old kit that has been around for many years and is still sold. There are newer more aggressive cam profiles around but this kit of matched parts is a proven performer.
You can check it out at Summit or Jeggs or Scoggin-Dickey
Old Mar 27, 2018 | 12:51 PM
vetteLT193's Avatar
vetteLT193
Design god
Yes. Get the ones with the self aligning tips so you don't need the guides (Crane makes them, gold full rollers).
If you don't go LT4 springs you can get away with 1.6 intake and 1.5 exhaust which is a good combo for the LT1. The only real gotcha to the job is you need to grind off the drip tabs on the valve covers or get new ones. If you have the carbon fiber valve covers (93-96) the drip tabs kind of shred off and it's not the best solution
Old Mar 28, 2018 | 09:40 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
I am doing the same thing myself. You can get Comp Cams cast steel full rollers, which are actually lighter and stronger than aluminum. There are now better springs available than "LT4" springs. Technology has marched on since the kits were developed. Some folks are now using springs from the LS series of motors, springs with oval wires etc.
As far as the drip tabs are concerned, you will need (just like I will need) to actually pull the covers and look inside. After all, the LT4 motors used composite covers and used 1.6 rollers. So look inside your valve cover and see what is there before plotting a course of action.
I assume you are going to use one of the screw in air plugs to pump the cylinder up and hold up the valve ?
Old Mar 29, 2018 | 12:20 PM
vetteLT193's Avatar
vetteLT193
The early LT1's had a different part number than the later ones. If it is an early car it will need to be ground down, later ones should clear.
Old Mar 29, 2018 | 12:30 PM
vette196's Avatar
vette196
i have a '96 and I'm installing Lunati VooDoo 1.6 rockers. Are you saying I'm OK with my valve covers or will the tabs need to be cut
Old Mar 29, 2018 | 02:42 PM
drcook's Avatar
drcook
In his first post he mentioned having a '96. I was bringing attention to that without putting up one of those finger point type rebuttals.
Old Mar 30, 2018 | 07:16 PM
mtwoolford's Avatar
mtwoolford
Be thankful it ain't a 96 LT4
To Rocker arms
