Just about anyone's LS swap harness will work? I'm running a FAST EZ LS kit in my 85. Was pretty straight forward. I used the stock sensors for the dash. Not sure what your going to use for a transmission?
I'm running a 05 LQ9 engine and 700R (LQ9 flexplate, stock transmission, stock converter), stock rad and stock fuel pump. Not sure how much longer the trans will last, as I have a heavy foot.
These guys do a complete wire harness swap over, if you want it to look near factory but you have to tear the car completely apart to get the old wiring harness. Then send it into them to swap over.
