C4 injector gone bad
Old Mar 28, 2018 | 12:57 PM
Tony Trans Am's Avatar
Tony Trans Am
Default C4 injector gone bad
Hi, did an ohms test and it seems as if an injector has gone bad.
1. Will injector cleaner bring it back (royal Purple atomiser)?
2. Do I replace the one injector or replace them all?
Old Mar 28, 2018 | 01:14 PM
PatternDayTrader's Avatar
PatternDayTrader
If it failed electrically then cleaner wont help. You didn't say the year of the car but typically people will replace the set of injectors and not just one. But, there is nothing stopping you from replacing just one.
Old Mar 28, 2018 | 02:48 PM
Tony Trans Am
Thanks, it’s a 1990 with 17000 miles from new.
Old Mar 28, 2018 | 02:52 PM
PatternDayTrader
Its pretty easy to remove the injectors on an lt1 car so one at a time makes more sense, but for an l98 I would replace them all at the same time.
Old Mar 28, 2018 | 03:20 PM
vette196's Avatar
vette196
Fuel injection connection.....they can help
Old Mar 28, 2018 | 11:41 PM
skyhawk50's Avatar
skyhawk50
I’ve used FIC several times. Bosch 22 lbs. (yellow). About $ 169 for a set of 8.
Old Mar 28, 2018 | 11:54 PM
aklim's Avatar
aklim
1. If the coil in the injector is broke, all the snake oil will do is what it is designed for. To drain your wallet.
2. Depends on you. If you are selling the car, buy something from a junkyard that is similar size and most important, cheap. If you are keeping the car, get FIC to sell you a reman set that has been tested. If they are Multec injectors, they belong in the trash can before they were installed. They don't play nice with ethanol. IIRC the coils were fuel cooled and ethanol and the insulation don't get along. If the snake oils drain your wallet at purchase time, you are lucky. At worst, they could eat the rest of the coils up.
Old Apr 2, 2018 | 10:47 AM
Tony Trans Am
Knowing nothing about injectors, are the white bits part of the injectors or protective covers. They look like part of.
Old Apr 6, 2018 | 02:49 PM
Tony Trans Am
Ok so the new injectors are in and I will be refitting the plenum tomorrow with new gaskets, I notice the gasket set comes with silicon sealant, do I need to use this on the plenum gaskets? I notice in a few you tube vids that people are able to re-use there gaskets when doing an injector swap suggesting they haven’t used any sticky stuff, is this the case? My original gaskets didn’t seem to have any, but were not salvageable due to age.
Old Apr 7, 2018 | 09:31 AM
Rod Schneider's Avatar
Rod Schneider
No silicone is needed on the plenum gaskets! Just makes it harder to clean up the next time...........
Old Apr 7, 2018 | 09:36 AM
aklim's Avatar
aklim
Unless you have something FUBAR on the surface I would NOT recommend it To hold it in place, just a dab is all you need.
Why would you even want to reuse the paper gasket? I don't even like it when I have to reuse rubber that has been sitting for a while. After sex, do you wonder if you can reuse the condom?
To C4 injector gone bad
