'84 steering rack
Old Oct 15, 2002 | 10:53 PM
buzzbomb's Avatar
buzzbomb
Default '84 steering rack
I'm replacing the rack and pinion on an '84. Any advice I should hear before I get to far? Do I need to take out the sway bar, or just disconnect it? What about the steering shaft from the steering wheel to the rack, do I need to remove it, or just loosen it, and then move tha rack away from it when disconnected? Thanks for any advice :cheers:
Old Oct 15, 2002 | 11:13 PM
JonM's Avatar
JonM
Default Re: '84 steering rack (buzzbomb)
Check the steering shaft...they are known to go bad on 84s...Be patient, the R&P is a little tough to get out.
Old Oct 16, 2002 | 12:43 AM
buzzbomb's Avatar
buzzbomb
Default Re: '84 steering rack (JonM)
Thanks, the whole thing is now loose, except for the steering shaft, I have it loosened on both ends, but I don't have enough clearance to get it out! Any hints? :smash: Can I take apart the little u-joint?
[Modified by buzzbomb, 4:55 AM 10/16/2002]
Old Oct 16, 2002 | 01:22 AM
JonM's Avatar
JonM
It collapses into itself...stick a screwdriver in where the bolt went through and push. Its like a piston
Old Oct 16, 2002 | 01:34 AM
buzzbomb's Avatar
buzzbomb
Aha, thanks, I didn't have the bolt all the way out, it was just lose, now if I could just get the rack out, I'll try again tomorrow, thanks for the help! :cheers:
To '84 steering rack
