Trying to identify this part
Old Mar 31, 2018 | 02:44 PM
jpipx's Avatar
jpipx
Default Trying to identify this part
I can't locate this item in my FSM, it's on the passenger side if the intake manifold. Looks like vacuum lines connected to it, but one end is broken off and looks like I need a replacement.
Old Mar 31, 2018 | 02:53 PM
ex-x-fire's Avatar
ex-x-fire
Its a vacuum check valve, It lets it pull & hold vacuum.https://www.summitracing.com/parts/r...SABEgIMifD_BwE
Old Mar 31, 2018 | 03:04 PM
jpipx's Avatar
jpipx
Thanks!
Old Mar 31, 2018 | 03:12 PM
whalepirot's Avatar
whalepirot
Think is is part of the HVAC vacuum operation system.
Old Apr 1, 2018 | 05:08 PM
WVZR-1's Avatar
WVZR-1
I stumbled upon this a very long time ago and I believe you have '93. Here's routing and GM Part # for you. I would imagine the part # has been replaced and there's very generic used most often. An OE/GM at the time I believe would have come with the elbow connector. I'm quite sure routing is correct.
Name:  Vacuum Tee LT-1.jpg
Old Apr 1, 2018 | 08:57 PM
Whaleman's Avatar
Whaleman
That seems to be where they always break. Mine did also. Dan
Old Apr 3, 2018 | 03:41 AM
Joe C's Avatar
Joe C
pretty much a generic part - try dorman #47150 - about $5 or $6 at just about any parts house. fairly sure a GM OE parts are discontinued, but they do show up on fleabay from time to time - i'm thinking they're running about $20. try part number 14056648.
BTW - running the dorman part on my 85 - no issues.
To Trying to identify this part
