Cluster issues
Old Apr 2, 2018 | 04:45 PM
Fish_Leg's Avatar
Fish_Leg
2nd Gear
Default Cluster issues
Good afternoon gents,
Forgive me if I am posting in the wrong location. (this is my first post)
I have a 86 coupe and i am having issues with my instrument cluster.
First issue:
Cluster lighting comes and goes, one moment it is bright and clean and the next it is SUPER DIM, there is no rhyme or reason why it changes.
Second issue:
The cluster will not read anything over 167mph. (What the hell....)
My cluster was rebuilt a few months ago by Batee.com. Bryan did a great job and replaced the broken bits and I elected to upgrade the incandescent bulbs to LED's while he had it. I have spoken in depth with him on this issue and it seems to be a car problem, and not a cluster issue. Any insight or suggestions would be super helpful.
Old Apr 2, 2018 | 05:22 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
First thing I'd check would be grounding problems.
Old Apr 2, 2018 | 08:44 PM
auto_cran's Avatar
auto_cran
I second what Ben says.
I recently had similar issues with the cluster on my '84. Turned out to be the ground - the culprit being the one right next to where the oil filter screws on. The bolt there was crazy loose.
Old Apr 3, 2018 | 10:19 AM
Fish_Leg's Avatar
Fish_Leg
2nd Gear
Thanks fellas,
Where would I find a diagram of ground locations so I can systematically check them all?
Old Apr 3, 2018 | 12:47 PM
belairbrian's Avatar
belairbrian
Originally Posted by Fish_Leg
Thanks fellas,
You will need to get the Factory Service Manual (FSM). They are model year specific. Try the for sale section or ebay. You can get the GM paper version or a CD with PDF files.
Old Jun 28, 2020 | 09:44 PM
RoboVette91L98's Avatar
RoboVette91L98
Cruising
First issue:
Second issue:
how often are you driving over 167 mph that issue two would be a problem? Wow. Haha, I didn’t even think these older corvettes would go that fast! What is your top speed? I just recently purchased a 91 C4 and I’m loving it!
To Cluster issues
