4+3 Rebuild Question>>
Old Oct 16, 2002 | 10:29 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default 4+3 Rebuild Question>>
My Father-in-law has an 84 with the 4+3 and the gear oil from the 4spd is leaking into the OD unit. I know there are only a couple places recommended to rebuild these units..
But I forgot who they are.. anyone have that info?
THANKS
Old Oct 16, 2002 | 01:41 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: 4+3 Rebuild Question>> (-=Jeff=-)
I had to send mine to new york , i can't remember the name of the outfit that did it, but maybe this may give you a place to start looking, sorry man, its the best i can do :cheers:
Old Oct 16, 2002 | 06:57 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
-=Jeff=-
Try http://www.skspeed.com 1-800-846-4252
I believe that CF member David Fulcher also does rebuilds of the 4+3. I've always found his posts to be reliable and at the level of a Master Mechanic for Corvettes. When mine need rebuilding I'm going to check with him first.
Old Oct 16, 2002 | 07:14 PM
ZylaRace's Avatar
ZylaRace
Default Re: 4+3 Rebuild Question>> (Mike_88Z51)
Dave Fulcher does an excellent job on the 4+3. There is a good chance that unit that went to NY, went to Dave to get done.
Also try gearzone.net
The 4sp gear box is leaking into the OD unit????? How did you come to this conclusion? The OD unit is under pressure. The gear box is an oil bath setup.
Old Oct 16, 2002 | 07:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 4+3 Rebuild Question>> (ZylaRace)
I didn't come to that conclusion.. My Father-in-law did. This has been on going for 2 years.. he checks the fluid once a month and the OD is always filling up past full.. So he is pretty sure the oil from the 4spd is going in there.
I will get in contact with Dave Fulcher, I have his email address somewhere.
Old Oct 16, 2002 | 08:10 PM
scorp508's Avatar
scorp508
If the OD is filling with gear oil, those clutch packs in the OD should be shot almost instantly.
Old Oct 16, 2002 | 08:28 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: (scorp508)
I would agree but the OD still works
To 4+3 Rebuild Question>>
