1986 Corvette Computer Flash / Software?
Old Apr 4, 2018 | 12:56 PM
FisherJ00's Avatar
FisherJ00
8th Gear
Default 1986 Corvette Computer Flash / Software?
First off has anyone worked with reprogramming the factory ECU on the 86 vette? If so is there a replacement chip involved with the process or is it as simple as the interface software itself performing a re-write of the factory ECU.
Recommendations for Software needed?
All help is appreciated!
Thanks,
~JF
Old Apr 5, 2018 | 05:53 AM
gerardvg's Avatar
gerardvg
Thanks,
~JF
Hi
You can use Tunerpro and a moates ostrich emulator, plug it into the ECM chip slot and add the supplied chip to the cable. Then you can do changes with a laptop quick and easy.
Note it is a steep learning curve to master this, always have a backup ecm chip if you stuff things up. You WILL NEED IT
See links below, you will need to download files for your year C4.
http://www.tunerpro.net/
http://www.moates.net/ostrich-20-the...eed-p-169.html
Old Apr 5, 2018 | 07:47 AM
FisherJ00's Avatar
FisherJ00
8th Gear
Thanks for those links!
I have done a large amount of Engine Management tuning and programming just not to a system this old. I had not found much in the way of programming and I was considering putting my extra Hal-Tech ECU system into the car which would have been a huge overkill in terms of capabilities. All to reprogram a few system limits on sensors so I would not have the SES light on in the systems and on my dashboard.
I learned the hard way when I first started tuning that a back-up is better than anything else you have done to the machine. nothing like messing up a tune and not having a previous version of the data to reload and having to start all of the work over again. Plus I am not planning on tinkering with the fuel injection or major items until further down the road I am just looking to clean-up some emissions and additional functions of the ECM to keep the codes from being active in the system.
Thanks!
~JF
To 1986 Corvette Computer Flash / Software?
