In the autoparts world a large number of parts are returned. The wicked thieves among us take advantage of this by placing old, bad, wrong parts in boxes when they send them back. I am guessing that was an actual SW505, but in todays world of autoparts we are unfortunately exposed to the "bad parts & bad people" syndrome.
Standard Motor Products TS-136, this is the one you want! I use this on my '84, I tried over a half dozen different suggestions (ALL of the usual suspects)...none of them operated as reported or intended. It's been a few years, but I'm 99% sure the TS-136 is the cross-reference equivalent of the Buick Grand National and TA turbo switch (like mentioned above). I've suggested this switch in a number of threads...ON~215°F...OFF~195°F. Good quality construction going 5 years strong, same in my brother-in-law's '84 TA! I found Rock Auto to have the lowest price and last time I checked, they still had them! Believe me, I spent a lot of time, money and got very quick at pulling the switch and stuffing in a new one without draining the antifreeze to discover the switch that actually works within this temperature range with consistency! Good luck👍
Just an update on this, a second SW 505 from autozone arrived and has the same style bullet connector the original OEM fan switch had with the flat area at the tip of the cone. I tested the new switch and it clicks into my 87's original connector perfectly. It appears as I may have actually received a thiefs return, the collar where the metal meets the ceramic is different (see pics above). Also, autozones limited lifetime warranty simply means "30 days".
C4 of Year Winner (appearance mods) 2019
Vet's-Vet: You're saying you think the 1st sensor you received was used, where this one is good? It plugs in and works fine? (Though you skipped the important part of confirming on/off values. From what I posted years ago, it LOOKS like this sensor should be closer to Vette OEM temps vs the lower one suggested in recent posts.)
Most all the posts I have seen from third gen and such show a 213° on 195 off. I have yet to install this one and the first one I got I believe was not an SW505 but was in a 505 box. Look at the area where the plastic meets the metal. It is so different I believe someone repackaged a product and returned it.
Give me a week or so and I should have the answer.
for future readers, i did the same wth ts136 and its excellent. expensive but excellent
You would need to check and confirm temps but a BWD TF58 is an accepted after-market. It's also mentioned to be an accepted for the GM # 3053190. How available and how many $$$? I don't need so I haven't searched. It was never inexpensive. When removed from GM it looks to have been 40+$$.
Give me a week or so and I should have the answer. Or a month or so....or a fiscal quarter or so?
So, 5 months later, a Kenwood excelon, carpet, kilmat and spindles replaced with heim joints and now it's time for the cooling system (again). I did a stovetop test (hard time at boiling point getting it to switch) of the TS136 and indeed it was as @'78CorvetteS.A. and @VikingTrad3r stated, my somewhat accurate test was ON @ 213° and OFF at 198°. The test was accurate enough to know it is what I want. So what about the accuracy of the SW505?? I don't know, I can't find it, it's here somewhere..........
Have a nice day
Donny
P.S. Are old rear bose speakers with anything or should I trash them ????
Have a nice day
Donny
For future reference for anyone trying the "boil test", at sea level, the temperature of the water will never exceed 212 F. Adding a cup or so of sugar to the boiling pan will allow the temperature to rise above 212 F.
