Alternator brackets on a '96 CE
Old Apr 6, 2018 | 10:51 PM
racerseks's Avatar
racerseks
Default Alternator brackets on a '96 CE
Okay, this is in regard to a '96 CE with LT4. Replacing the alternator. Seems the last time it was done, someone didn't completely install one of the brackets. It's a black piece of iron, with angled ends. Looks like it bolts the the exhaust manifold . Anyone have a pic of theirs, so I can be sure of placement? Also, any tools tips for bolting it to the exhaust manifold? Might save me some time tonight...thanks!
Old Apr 7, 2018 | 07:29 AM
WVZR-1's Avatar
WVZR-1
This might do for mounting. Do you have the missing brace? The 3d brace you see is from the compressor/alternator mounting support. Is that maybe the one you're questioning?
Name:  LT Alternator brace.jpg
I stumbled upon another this AM
Name:  LT1-4 Braces.jpg
Old Apr 7, 2018 | 07:42 AM
allout1's Avatar
allout1
I have a 96 ce with lt1 I can take pics and post if you think it's the same
Old Apr 8, 2018 | 12:40 AM
gdl2165's Avatar
gdl2165
I attempted to get some pictures, kind of hard to do with the ASR module mounted right over the top of them. My LT4 actually has three of those tubular braces. One mounts pretty much vertically from the alternator bracket down to the second manifold stud. The other two angle back and mount one over the other on the third manifold stud. I drew some red lines on these pics along the edges of the braces. The shortest line on the first photo is the manifold end of the brace that's marked in the second photo.
Old Apr 8, 2018 | 07:18 AM
jpipx's Avatar
jpipx
Attachment 48271801
Attachment 48271836
I'm missing the same bracket, #7 in the image above on my 95 coupe 6-speed!
OP: Which model C4 is your bracket missing on? I found that it is present on my 95 vert with automatic transmission.
I was going to make a new one when I have time. Would love to find one on line if I could find the OEM part number.
Old Apr 8, 2018 | 07:42 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by jpipx
I'm missing the #7 in the image above on my 95 coupe 6spd.
10128423 for #7 - you should be able to verify from this link except in this image it will be #6 NLA OE/GM new but from time to time inexpensive I'd think on eBay or maybe a call to the Corvette salvage guys.
https://www.wholesalegmpartsonline.c...category=19443
Old Apr 8, 2018 | 09:23 AM
csthews's Avatar
csthews
Often when the exhaust manifold is replaced, the braces are left off because either the manifold does not have the correct mounting studs, or the installer just decided that they were not necessary. I'm not sure about the LT4, but if you leave the braces off of the LT1, you may notice a vibration every time the air compressor cycles.
Old Apr 8, 2018 | 09:47 AM
csthews's Avatar
csthews
Here is a pic of the 2 brackets on my LT1. I didn't have the correct mounting studded bolt (not sure of the correct name for the bolt) so I had to improvise with a stud and 3 bolts.
Old Apr 18, 2018 | 10:38 PM
racerseks's Avatar
racerseks
Attachment 48271801
Attachment 48271836
Looks like I have them all...thanks!
Old Apr 18, 2018 | 10:40 PM
racerseks's Avatar
racerseks
Awesome! Thank you...Turns out I have them all. One just wasn't bolted down...
Old Apr 18, 2018 | 10:42 PM
racerseks's Avatar
racerseks
I will have to check on that one too! I have the three for the alternator though.
To answer your question...it's a '96 CE with LT4.
Old Apr 18, 2018 | 10:43 PM
racerseks's Avatar
racerseks
Good idea. I have been getting some good parts from the salvage yard lately...
Old Apr 18, 2018 | 10:44 PM
racerseks's Avatar
racerseks
Yea, I think one of mine just wasn't bolted down after a previous alternator replacement...probably 'cause it's a bit hard to get to, but it's back on now...thanks!
Old Apr 18, 2018 | 10:47 PM
racerseks's Avatar
racerseks
Thanks for the pic!
Old Aug 30, 2025 | 03:51 PM
vwcorvette's Avatar
vwcorvette
So this is what I came up with. Ignore the crappy welds. I know I can do better.
Virtually no flex now.
To Alternator brackets on a '96 CE
