Coolant temp sensors
Old Oct 16, 2002 | 01:15 PM
jsaunde2's Avatar
jsaunde2
Default Coolant temp sensors
OK, how many sensors are there and which ones control what?
Specifically, I am having a problem with erratic readings on my digital temp gauge. The gauge will sometimes read accurately, an appropriate reading for what the analog gauge displays, and sometimes will jump around wildy, like 180, 170, 60, LO, 180, etc.
So where does the digital gauge get its reading and what else should be reading from there?
BTW, I'm trying to track down an intermittant stumble/miss and there appears to be a correlation.
Jason
Old Oct 16, 2002 | 02:10 PM
El Guapo's Avatar
El Guapo
St. Jude Donor '03
Default Re: Coolant temp sensors (jsaunde2)
I don't know if the LT4 is different but on my LT1 there are two coolant temp sensors. One on the passenger side of the block and one on the front of the waterpump. The one on the block is where the analog reading comes from, the one on the waterpump is where the digital reading comes from. Hope that helps.
Old Oct 16, 2002 | 03:12 PM
jsaunde2's Avatar
jsaunde2
Default Re: Coolant temp sensors (El Guapo)
Thanks, do you know which one the ECM uses?
Jason
Old Oct 16, 2002 | 04:32 PM
dlmeyers's Avatar
dlmeyers
Front, Coolant Temp Sensor (CTS)
dlmeyers 90 coupe zf6 3 speed shocks
To Coolant temp sensors
