Brake rotor spec/thickness 84
Old Apr 10, 2018 | 10:36 AM
79C3tnd's Avatar
79C3tnd
Default Brake rotor spec/thickness 84
I have a friend who is converting brakes on his 69 racer to C4 brakes all the way around. Long story short, can someone tell me how thick the rotor on an 84 is? I can't seem to find specs on this anywhere. Thanks in advance!
Old Apr 10, 2018 | 02:09 PM
Hot Rod Roy's Avatar
Hot Rod Roy
The original (new) rotor thickness is 20 mm. The minimum recommended thickness is 18.4 mm.
Old Apr 10, 2018 | 08:24 PM
79C3tnd's Avatar
79C3tnd
Thank you!
Troy
To Brake rotor spec/thickness 84
