Which is the pressure side, 700R4?
Old Oct 16, 2002 | 04:08 PM
gene284's Avatar
gene284
Default Which is the pressure side, 700R4?
Is the top or bottom tube fitting on the transmission the pressure side?
Old Oct 16, 2002 | 05:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Which is the pressure side, 700R4? (gene284)
I can't believe it, my GM Shop Manual only refers to them as:
lower line=the upper fitting line
upper line=the lower fitting line
I wonder if these correspond to hookup at the radiator??
