erratic coolant temp readings
Old Oct 16, 2002 | 06:11 PM
jsaunde2's Avatar
jsaunde2
Default erratic coolant temp readings
I have been getting occaisional erratic digital temp readings, like it reads 180, 170, 60, LO, 130, 170, etc. changing every second or two. This is usually associated with a severe miss/stumble.
I just replaced the water pump ECT sensor with no effect.
Any ideas? Could I have damaged the sensor by overtightening? Could this be and ECM or general electrical fault?
Thanks for your help.
Jason
Old Oct 17, 2002 | 03:43 PM
jsaunde2's Avatar
jsaunde2
Default Re: erratic coolant temp readings (jsaunde2)
Common guys, someone has to have some idea. Or did I just **** everyone off somehow?
Jason
Old Oct 17, 2002 | 07:16 PM
Dan Parker '96's Avatar
Dan Parker '96
There's also a coolant sensor in one of the heads (if I remember correctly). May want to check it also.
Old Oct 17, 2002 | 07:50 PM
runnin'meragged'93's Avatar
runnin'meragged'93
Mine was doin' the same about 3 wks. ago. There is another coolant sensor on the passenger side head, right behind the oil dip tube. Replaced that and my problem went away.
Old Oct 17, 2002 | 09:06 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I just had mine fixed last week, it was doing the same thing. the temp sensor on the water pump was shorting out.. I beleave the one on the head is for the analog gage
[Modified by fsr402, 8:07 PM 10/17/2002]
Old Oct 18, 2002 | 01:06 PM
jsaunde2's Avatar
jsaunde2
Default Re: erratic coolant temp readings (fsr402)
Thanks for the help.
I am wary to replace the water pump sensor as I just replaced it and it didn't help the problem.
Maybe I'll just go ahead and replace both and hope it fixes my problem.
I'm kind of worried I have a more general fault as I jst replaced the sensor.
Jason
Old Oct 18, 2002 | 03:07 PM
jefft84's Avatar
jefft84
Dit you replace the wiring pigtail with the sensor? I run into this alll the time on GM products crappy connection to the sensor due to wiring breaking down.
Old Oct 18, 2002 | 03:11 PM
JB'S LT4's Avatar
JB'S LT4
Default Re: erratic coolant temp readings (jefft84)
the problem lies in either the water pump sensor or the pigtail wiring harness going to it...I also had this problem for a while ..The sensor on the head is for the needle gauge on the dash and would have no affect on the digital readout..
Old Oct 18, 2002 | 03:14 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Could be a lot of air in the system.
Old Oct 18, 2002 | 03:31 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: erratic coolant temp readings (PeteL)
Air bubbles passing the sensors could cause some very erratic readings. Burp the system (remove all the air) and keep the tank full.
Old Oct 18, 2002 | 05:33 PM
jsaunde2's Avatar
jsaunde2
I did not replace anything past the plug. That is likely the problem as I had to replace it because I broke the plug on the sensor side.
How would I replaxce this? do I just have to splice in a new plug?
Also, How would I "burp" the system? I bled all of the air out of the bleed screw like always.
Jason
To erratic coolant temp readings
