What are these Wires???
Old Oct 16, 2002 | 07:43 PM
C4Dreams's Avatar
C4Dreams
Default What are these Wires???
Help i found these today while painting my engine. what do these goto i cant find anything... http://www.geocities.com/phazin2002/help.htm
C4Dreams
Old Oct 16, 2002 | 07:46 PM
Tom73's Avatar
Tom73
Default Re: What are these Wires??? (C4Dreams)
Think they are part of the air pump control. Should be a black plastic box behind your hand in the pic. It is on the passanger side of the air intake at the front of the engine. Has a metal pipe going from it over to the air pump. Believe those wires plug in inside the box.
tom...
Old Oct 16, 2002 | 08:39 PM
C4Dreams's Avatar
C4Dreams
IF it says its a bad link try again tommorw, the geocities dont let u have so many hits b4 it shuts you down...Gata luv stuff that used to be free and now charges and limits so much that u cant do anything these days without paying.
C4Dreams...Btw i dont see any box..
Old Oct 16, 2002 | 08:51 PM
atotalnincompoop's Avatar
atotalnincompoop
have you eliminated anything from the front of your engine? :cheers:
Old Oct 16, 2002 | 09:43 PM
C4Dreams's Avatar
C4Dreams
Default Re: What are these Wires??? (atotalnincompoop)
No but the previous owner might have.
C4Dreams
Old Oct 16, 2002 | 11:16 PM
dtorc4's Avatar
dtorc4
Those two plugs are for your AIR switching valve and your AIR diverter. It doesn't look like you have the diverter valve in there - it would be mounted right next to your A/C compressor toward the center of the engine. Your switching valve is mounted on the other side of the A/C. They are two small black boxes with hoses and vac lines running from them.
If they are not there, there is a chance your catalytic converter and/or AIR pump might be gutted. :cheers:
Old Oct 16, 2002 | 11:20 PM
C4Dreams's Avatar
C4Dreams
Default Re: What are these Wires??? (dtorc4)
Why yes yes, the kitty has been gutted... :cheers:
So i dont have to worry about the plugs then...Ahhhh :cheers:
C4Dreams
To What are these Wires???
