Cooling system flush, etc. on an LT4
Old Apr 20, 2018 | 10:18 PM
racerseks's Avatar
racerseks
Default Cooling system flush, etc. on an LT4
Any good write ups on doing a cooling system flush and fill on a '96 LT4? I've only had gen 1 stuff up until this point, so reverse cooling, bleeder valves, etc, are all new to me. Thanks!
Old Apr 20, 2018 | 11:15 PM
Bobo Greybeard's Avatar
Bobo Greybeard
I would really suggest you find a BG dealer in your neck of the woods that has the coolant flush machine. It is a ton better than what you can do yourself or at least what I have been able to do in the past by myself. It also lubricates and cleans the rust out of your complete cooling system IE Block, water pump, heater core, radiator ect. It cost a bit, but it is well worth it, especially on a Vette.
Bobo
Old Apr 20, 2018 | 11:18 PM
racerseks's Avatar
racerseks
I'll consider it, but like to give it a shot to better understand how the system works, etc. Thanks for the reply!
Old Apr 21, 2018 | 08:35 AM
fake's Avatar
fake
When car is cool drain radiator passenger side Then pull two knock sensors ( watch for coolant on body where full mask throw away paper suit etc coolant is a hazard to man and paint. Then buy distilled water at walmart two gallons is enough pour in passengers side black tank. Then start and run car for 4 minutes. Then shut car off and wait till cool Then start again and add coolant as it reaches temperture the stat will open then release above stat bleed screw and wait for full stream and no bubbles.Take car for ride and watch for warning lites and temperture rise. Shut car off and when cool top off with coolant G20 i believe is the one
Old Apr 21, 2018 | 09:25 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
In the procedure above^....when did you flush/drain??
Dear lord....that is massive over kill.
Fastest, best way to do it on an LT1:
1. Drain radiator and block as described above with the radiator drain and knock sensors (both sides).
2. Remove the upper radiator hose from the t-stat housing, then use that hose as a flush port, to flush out the radiator using a garden hose. Flush 'till drain water runs clean from the radiator, shouldn't take long. Re-connect rad hose to t-stat housing.
3. Remove the heater core hose from the water pump, connect to a garden hose and now you're "reverse" flushing the heater core and flushing the heads and block all at the same time, water will come out the block drains (knock sensor holes). Flush until clean -shouldn't take long.
4. Re install knock sensors, hear core hose, fill system with premixed coolant or mix your own with distilled water, top off, open bleeders until coolant comes out, close bleeders and top surge and over flow tanks...you're done.
Old Apr 21, 2018 | 09:56 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Old Apr 21, 2018 | 11:41 AM
aklim's Avatar
aklim
I guess I am curious how bad your system is. If you pull the KS and find a bunch of oily gunk, you might have to get the oil out. IIRC, MB uses a procedure to de-oil and then decalcify any crud there. Now if you are having coolant for 20 years and just topped off every so often, I'd probably go that route to be sure. OTOH, if you have been cleaning regularly, I'd probably be ok going to some place where I can watch them flush the coolant if you don't want to risk it going all over the place or let it flow into the storm sewer some dark night and hope nobody calls it in to the cops. Your call.
Old Apr 21, 2018 | 01:58 PM
Purple92's Avatar
Purple92
NO !!! The C4 cooling system capacity is not 8 quarts - it's 16 quarts. Draining the radiator and pulling the block drains - then pouring in only two gallons of distilled water only is a good way to warp the heads !!!
Old Apr 21, 2018 | 02:02 PM
Purple92's Avatar
Purple92
THIS is the right way to do it !!!! Expect to buy 2 gallons of full strength coolant and two gallons of distilled water, or 4 gallons of premix if you prefer to pay extra for the convenience of pre-mix (not recommended).
Old Apr 21, 2018 | 02:44 PM
aklim's Avatar
aklim
2 gallons of distilled water plus 2 gallons of coolant makes 4 total gallons ot 16 quarts since it is 4 quarts to a gallon, isn't it?
Old Apr 21, 2018 | 04:22 PM
dizwiz24's Avatar
dizwiz24
Only way to do it right is remove both knock sensors.
in fact, i believe a speed shop (before i knew how to do the work myself) didnt do this during a head/cam swap and the brake parts cleaner they sprayed to clean the deck got into my cooling jacket around the block.
a year or two later the upper radiator hose blew at a race from dry rot - likely weakened from the inside out by solvents.
Old Apr 21, 2018 | 04:33 PM
aklim's Avatar
aklim
I don't soak my hoses in brake cleaner but. They do get hit from time to time on the outside when I wash oil off the engine. Not sure if that makes a difference. I'm not sure how much solvent they used but that sounds like a lot of solvent to cause such an issue.
Old Apr 21, 2018 | 09:54 PM
racerseks's Avatar
racerseks
Doesn't sound too bad. Thanks for the details!
Old Apr 21, 2018 | 09:56 PM
racerseks's Avatar
racerseks
Awesome! Thanks for the thorough details! Sounds like a very good way to get it cleaned up!
Old Apr 21, 2018 | 09:57 PM
racerseks's Avatar
racerseks
Originally Posted by don hall
Important ......
knock sensors should come with a thread sealant applied, if not, apply sealant.
Torque is 14 ft lb.
Thanks...can I use the same ones over again, or do they need to be replaced? If so...what kind of sealant? Thanks!
Old Apr 21, 2018 | 10:00 PM
racerseks's Avatar
racerseks
It's been sitting a while. Not too sure how bad it is, so figured I'd plan on the worst. When I was younger, I might do something like that, ha ha...but these days, I just feel kinda guilty, and will probably find some place to drop it off. Thanks!
Old Apr 21, 2018 | 10:01 PM
racerseks's Avatar
racerseks
Thanks for the word of caution. I'll make sure it's full!
To Cooling system flush, etc. on an LT4
Old Apr 21, 2018 | 10:02 PM
racerseks's Avatar
racerseks
Thanks for the vote. Feeling confident about it, and yea...I have two big jugs of the full strength, and will get some distilled water.
Old Apr 21, 2018 | 10:05 PM
racerseks's Avatar
racerseks
Yea, I believe it! I am by far not the fastest at doing any of this stuff. What people quote on time involved is usually multiplied by at least 3 for me...but I clean and replace a lot along the way, and I try to be very thorough. Thanks for the comments.
Old Apr 22, 2018 | 12:38 AM
aklim's Avatar
aklim
Have the shop pull the sensors and see what comes out. If some rusty stuff comes out, I'd have them backflush it with a hose. If not, constant maintenance will work. I just keep my cars on the same pattern as the 3 MBs. So every 3, drain and replace coolant, every 2, flush brakes. Truck has long life coolant so every 100K
