1993 Front Upper Shock Bushing
Old Apr 22, 2018 | 11:36 AM
Boss Lady's Avatar
Boss Lady
Default 1993 Front Upper Shock Bushing
I recently installed a set of Bilstein B6 Performance Shocks on my 93 with the standard suspension (FE1). The front upper mounting plate has a large diameter hole that I was wondering if there was a special bushing / grommet that should be used. The shocks mounted up O.K. with the supplied bushings, but I wanted to double check to see if there was a special grommet that was required to take up the space of this hole in the mounting plate. If so, the part number and manufacturer would be appreciated. Thanks!
