Hood problem (help)
Old Oct 17, 2002 | 02:41 AM
tko5o's Avatar
tko5o
5th Gear
Default Hood problem (help)
I have a 88 Corvette, the hood won't release on the passenger side, how can I get it to release so I can pop the hood and fix the problem.
I can be reached Via E-mail @ tko5o@hawaii.rr.com
Brian :confused:
[Modified by tko5o, 6:48 AM 10/17/2002]
Old Oct 17, 2002 | 03:02 AM
Silver89's Avatar
Silver89
Default Re: Hood problem (tko5o)
Sometimes if you have someone else hold the handle, and sorta bounce it up and down over the latch, it'll pop out. Just don't push too hard and crack the hood.
Old Oct 17, 2002 | 03:06 AM
paintdaddy's Avatar
paintdaddy
Default Re: Hood problem (Silver89)
I bought that tool from MA.I have had to use it a couple of times ,it works good. :seeya
Old Oct 17, 2002 | 04:52 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Ditto...
Buy the tool, I always keep it on hand just in case....but never had to use it yet.....knock on wood!!!! :cool:
Old Oct 17, 2002 | 05:01 PM
secondchance's Avatar
secondchance
I would try this first. It worked for me most of the time. When all fail, then use the tool designed by Gorden Kilbrew.
Good luck.
Old Oct 17, 2002 | 05:04 PM
hngacurv's Avatar
hngacurv
Default Re: Hood problem (secondchance)
I read an article with Gordon Killebrew and he says the first tool a C4 owner should have is the one he designed to reach in and pull the hood cable. He says sooner or later you will need it.
Old Oct 17, 2002 | 05:46 PM
tko5o's Avatar
tko5o
5th Gear
Default Re: Hood problem (castivers)
Where do I buy the tool?
Brian
Old Oct 17, 2002 | 05:49 PM
JonM's Avatar
JonM
Why doesn't someone make a diagram and post it with the dementions...Its only a piece of bent rod.
Old Oct 17, 2002 | 05:52 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Default Re: Hood problem (JonM)
Old Oct 17, 2002 | 06:45 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Hood problem (Dudeurgettnavette)
Try http://www.geocities.com/yosemite/7491/tips.html
Old Oct 20, 2002 | 12:34 AM
purple jinx's Avatar
purple jinx
Default Re: Hood problem (lou sylvestri)
Thanks for the diagram, I'll be getting my friend to make me one of those puppies. :cheers:
To Hood problem (help)
