Question About TPS Voltage 1984 Corvette
Old Apr 22, 2018 | 11:53 PM
crossfireclint's Avatar
crossfireclint
Default Question About TPS Voltage 1984 Corvette
I have my 1984 Corvette TPS voltage set at 0.54 volts. I found 0.54 to be the recommended TPS voltage in manuals and C4 forums. My buddy is a GM dealship mechanic and he's telling me to set it in the 0.60 to 0.62 volts region and I'll notice slighty better throttle response. Just wondering if anyone has also heard of setting at a slighty higher TPS voltage increases performance? I was thinking of trying it just for the heck of it.
Old Apr 23, 2018 | 12:02 AM
zachaeous's Avatar
zachaeous
0.545 volts +/-0.025v at closed throttle. I have not heard of that but it is not that far from the factory spec. Try it and see how it goes.
Old Apr 23, 2018 | 08:42 AM
84 4+3's Avatar
84 4+3
I believe the 84 is actually .525 +/- .075. So you're in spec if you're getting .540.
Bumping the TPS up helps on a tpi car but the crossfire I don't believe it is reccomended.
To Question About TPS Voltage 1984 Corvette
