1985 AC question
Old Apr 29, 2018 | 01:06 PM
TBSS/85vette's Avatar
TBSS/85vette
Default 1985 AC question
Last summer I installed a new Delco AC compressor and at the same time replaced the low pressure switch in the upper line and the 2 switch/sensors in the lower line. The AC relay was replaced also, I just wanted to eliminate future problems. I vacuumed the system down and recharged with the correct oil and R134 and the system cooled flawlessly for the rest of the summer. After the car was put away for the winter it was started a few times to run the compressor to keep the seals lubricated and no problems. Now the car is out for nice weather and the compressor does not run. The fuse is not shorted and first time ever you can't jump the compressor at the low pressure switch with a wire and I'm assuming it's electrical. The usual suspects were already replaced. The only thing not touched was the control panel in the dash. Where would you start looking?
Old Apr 29, 2018 | 01:27 PM
84 4+3's Avatar
84 4+3
System pressure first. Then energize the clutch with the car off to see if it'll engage. Check fsm check outputs from hvac module. Then start checking relays and sensors if the rest checks out. Cant hurt to check continuity on the circuit too.
Old Apr 30, 2018 | 12:02 AM
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
to elaborate on engaging the clutch with the car off, set the key to 'run' and turn the A/C to MAX. This will engage the compressor clutch and you'll hear a click from the compressor. If that doesn't happen then you're looking for something electrical. It sounds like you already know that but just filling in details
To 1985 AC question
