Improving the L98
Max lift for factory, non-modified 113 casting heads from a mechanical perspective is 0.520" lift.
Max duration is dependent upon ability to tune the combination. My experience is to keep it between 215-225* for the most radical combinations. Drivability and idle quality are sacrificed as duration is increased past 225*.
Depending on whether he is rebuilding the bottom end or not, a bonus for ditching the TPI intake is the ability to run more compression ratio since there is no stupid hump in the cylinder pressure (which is where the torque hump comes from). There are all manner of quotes for CR on L98 engines, but I believe they were probably 9.5:1, whereas the LT1 was 10.5:1. That would actually allow a boost in cylinder pressure at all rpm. Also, depending on how much money the OP wants to put into this, he could do a lot better than the stock L98 heads. The Vortecs are better flowing, but the Fast Burn heads are considerably better flowing yet (at all valve lifts, not just high lift) while not losing any low-rpm performance.
cardo, you're just wrong on several things. The TPI intake's main limitation on rpm is caused by its length, not its runner cross section. You even mentioned the Helmholz effect it creates. Again, I think this peaks at around 3200rpm on a stock TPI intake, and that is caused by the resonance happening in phase with the intake valve's opening event. But what happens at an rpm where the resonance is 180* out of phase with the intake valve's opening - i.e., the rpm at which the resonance is now reducing intake pressure rather than increasing it? Yep, the increase in intake pressure now becomes a decrease of equal magnitude, at 50% more rpm than the torque peak. Cylinder pressure (and therefore torque and therefore power) falls off a cliff due to that resonant restriction. And that's exactly why an L98 is all done before 5000rpm. Helmholz theory holds that massively increasing the runner cross section can raise the resonant peak and cliff, which is what the FIRST unit accomplishes. But of course it will also lose something below the peak due to the slower flow velocity of the larger runners. And it won't widen the torque curve: it just moves everything higher, and you still have the unhelpful peak and cliff.
You're also wrong about dual-planes being useful for torque on a port-fuel-injected engine. The key to whether an intake is single- or dual-plane is how many intake valves "see" each throttle blade. If 100% see all the blades, then it's single-plane. If only half the valves see each blade, it's a dual-plane. If only a quarter of the valves see each blade, it would be a four-plane, and if only 1/8 of the valves see each blade (e.g. individual stacks with throttle blades in each), it's an eight-plane intake. Here's a tip: if the throttle body only has one blade, then by definition that intake is a single-plane intake. It can be no other way, because all the runners and valves "see" 100% of the throttle blades (because there's only one blade!). The only way to have a dual-plane intake is to have a two-barrel or four-barrel carb or TB that is physically separated all the way to the blades, such as on that Chevy performance piece you linked. In that setup, each valve can only see 50% of the throttle blades. No divider, no dual-plane. It really is that simple.
So the T-ram, convoluted though it is, is absolutely still a single-plane intake. A tunnel ram - even with its large plenum, and regardless of how many carbs/TBs sit on top of it - is still typically a single-plane intake. You could put a divider in the plenum and make it a dual-plane or even a four-plane, but I don't know why anyone would do that. All factory port-FI intakes I know of are single-plane, with the only exception being the very few that have individual stacks and throttles for each cylinder (E30 M3 comes to mind, but there haven't been many). There just aren't compelling reasons to make things more complicated.
That Chevy performance piece you linked is surely intended to be used mainly with nitrous injectors in the bosses, not fuel injectors. There are multiple reasons it would be kind of silly to use it as an EFI intake. Not the least of those reasons is the four-barrel throttle body that would be required. Surely GM intends this mainly for those that want to use a carb on an LS engine? I know some very, very highly placed LS builders, and they wouldn't use this intake for EFI on a dare. Using a dual-plane carb intake converted to EFI on an L98 to increase "torque" would just be dumb.
If so I will surely go for this intake and look to a higher CR. I will dig into the specks on head options and pare them with what intakes make the most sense.The long term goal for this car is to have fun and travel in it. So a little wider power band sounds good, reasonable drivability and maintain the same or at least similar fuel consumption. I know the last one is very directly tied to my driving.
If so I will surely go for this intake and look to a higher CR.If my sources are right by reverse engineering the sizes based on assumed/ known values:
Stock is 10.25 for my 1990 engine with 7cc in reliefs on the flat top pistons. I am fairly sure these are the same ones used on the F-body LT1 engine. Working from an assumed .040 compressed thickness gasket at 4.01 diameter yields a deck clearance of 0.02". If you carry these values to using LT1 heads on a stock gasket puts the engine at about 10.7:1 and if I run the same thickness 0.026 gasket I have on my LT1 now it puts me at about 11.2:1. I run 92/93 octane only so with some conservative tuning I don't foresee a huge challenge avoiding knock. The more I play with the numbers the more I like where this is going.
Some of you need to have a Coke and a smile. It would be wise to agree to disagree and keep the drama down.
