ok i can't keep it up again, the feul pressure that is, when i turn the key on the feul pressure jumps up and then instantly drops off again, i can hear it draining back but can't tell were exactly the sound is coming from. i have a new pump and filter, new regulator etc. i figured that i had a leaky injector so i lifted the feul rails and turned the key on to pressurize the system to check for a leak but found none. on one of the injectors i could smell a little feul but that was it, maybe that's enough, what do you guys think :cheers:
here a dumb one, which one is the return line? I thought it might be this so i just put a rebuild kit into it, but the problem is still there, could i have installed it wrong, it seemed idiot proof? :cheers:
[Modified by atotalnincompoop, 7:14 PM 10/17/2002]
Be sure to check on the sending unit itself the metal lines to see if between the pump and the top of the tank there is not a hole anywhere as was the case with mine.. It seems the metal lines rub the tank and eventually caused a hole in the soft metal lines.. I had the line welded..Fixed the problem
