I Hate CAGS
Old Oct 17, 2002 | 09:04 PM
Red Tornado's Avatar
Red Tornado
Default I Hate CAGS (1990)
I know , I know, this topic has been posted many times. But I'm looking for something specific, and I can't find the answer :cry So please bear with me......I'd like to remove the relay associated with CAGS. In a 1990, does anyone know exactly which one it is? I know it with throw an engine code, which is fine, until I get the disconnect kit to do it right. And yes, I need to get a service manual :jester First one with the correct answer gets a free case of beer! :cheers: Just kidding :D
[Modified by bradvette, 8:38 PM 10/17/2002]
Old Oct 17, 2002 | 09:43 PM
90Z51Vette's Avatar
90Z51Vette
Default Re: I Hate CAGS (bradvette)
Just unplug the connector to the solenoid on the left side of the transmission. The first-to-fourth light will still be displayed on the instrument panel, but it won't set any codes.
The kits available are nothing more than covers for the open ends of the unplugged connector.
I plug mine back in once a year to see if it still works, and after a day or so I can't wait to unplug it again!
I'll pass on the beer, but good bottle of Merlot would be nice...
Mark
:cheers:
Old Oct 17, 2002 | 09:49 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Piece of cake! The connector is on the driver's side of the tranny about half way up from the bottom, about 3/4 the way towards the rear. Just unplug and get the disconnect kit when you can to plug those connectors. You'll feel really bad when you see how easy it is to end the suffering. :D
Old Oct 17, 2002 | 09:50 PM
Red Tornado
Default Re: I Hate CAGS (90Z51Vette)
Thanks guys :D Until I get the kit (if I even do), what is recommended as a permanent plug for each end of the connectors?
Edit: By the way, I really like Merlot myself, its good for the heart, the soul, and the head! :D
[Modified by bradvette, 8:51 PM 10/17/2002]
Old Oct 17, 2002 | 10:36 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Just tape the ends the best you can, tape the wire from the wiring harness back to something to keep it from swinging around and breaking off.
Old Oct 18, 2002 | 02:08 AM
vettl83's Avatar
vettl83
Default Re: I Hate CAGS (PeteL)
If your in the market for an aftermarket or custom burnt prom chip they will have the CAGS programmed out of them. 84 CF 91 ZR-1
Old Oct 25, 2002 | 01:02 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
You can buy $$$$ a bypass from all these Corvette Central...Ecklers....Mid AMERICA.....They all have these products....easy to install.... :smash: :smash: :smash:
Old Oct 25, 2002 | 01:43 AM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Unless you plan on driving in a lot of rain you can probably get by with electrical tape and tie-wraps. Then check every time during an oil change. :yesnod:
Old Oct 25, 2002 | 02:44 AM
drive it's Avatar
drive it
bradvette-does your front bumper increase airflow to the radiator????
Old Oct 25, 2002 | 04:48 PM
dlmeyers's Avatar
dlmeyers
Default Re: I Hate CAGS (drive it)
Yes, I too hate CAGS. Even Dave McClellan, C4 Chief Engineer hated CAGS. It was put on there to improve the fuel average like .1 mile per gallon or so. Maybe a little more. They wanted to make sure the C4 was not branded a gas guzzler. At a meeting with the press, he made sure everyone knew what wire to cut.
Should you not want to crawl under the car, the relay for the cags solenoid is back on the fire wall near the battery. When you get the factory service manual, you can locate the relay and just unplug this until you get the kit. I did the kit. Didn't want a wire plug dangling around a connector.
Love rowing through the gears.
Enjoy.
dlmeyers 90 coupe zf6 3 speed shocks
Old Oct 25, 2002 | 09:29 PM
Raistlin's Avatar
Raistlin
I've got a '90, just unplugged the connector from the tranny. My shift-up light does not stay on. I have no codes thrown. Unplug it now, CAGS is horrible!!
Old Oct 26, 2002 | 12:29 AM
Bimota Guy's Avatar
Bimota Guy
Default Re: I Hate CAGS (Raistlin)
Complete with pics... (this is for the LS1 cars, but should be relatively the same)
http://www.ls1.com/link_cags.html
I'll be heading to Radio Shack tomorrow! :D
[Modified by Bimota Guy, 8:32 PM 10/25/2002]
Old Oct 26, 2002 | 12:33 AM
GlockLT4's Avatar
GlockLT4
Default Re: I Hate CAGS (khornet)
I hate it too... comes on when i don't want it to (which is only when i'm in bad weather or something and i don't want to accelerate fast.
To I Hate CAGS
