Corvette Central
Old Oct 17, 2002 | 10:09 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Corvette Central
I placed an order for Cross drilled Rotors with Pad set ($409.00)...P/N 194282.....
Stock 1984 size....OK!!!!
GIVE ME YOUR THOUGHTS.....SOULD I CANCEL?????
thanks
tony :eek: :cool: :eek:
[Modified by oldace84, 9:15 PM 10/17/2002]
Old Oct 18, 2002 | 01:44 AM
qwerty111's Avatar
qwerty111
Default Re: Corvette Central (oldace84)
Probably a dumb question, but....
What would be the advantage of this modification on a 1984 'Vette? I can see it if you have a 383 or some big time HP which would require more stopping power, but for a stocker, doesn't seem feasible to me.....but then my old age must be showing.
Old Oct 18, 2002 | 01:48 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Corvette Central (qwerty111)
Better brakes are never a bad idea. It doesn't matter how long it takes you to get to a speed, once you are there you still have to stop. After you hit the brakes the car isn't gonna care what type of engine you've got, it's only gonna worry about your inertia and how much heat you can dissipate.
I believe your question is more directed torwards the line of "should I have ordered larger brakes" Well, maybe, maybe not. Again it wouldn't be a bad idea, but there are fitment issues for certain wheels sizes and such. Better brakes are never bad, but you'll have to look at what's involved in making those brakes work on your car.
:cheers:
Old Oct 18, 2002 | 06:16 PM
guywade's Avatar
guywade
what size rims are on the 84 , will 13" rotors fit, that sounds and works better :cheers:
Old Oct 18, 2002 | 07:59 PM
RED84CF's Avatar
RED84CF
1984 Corvette brakes suck! They stop the car under normal driving but I wouldn't want to try and stop in a hurry if going really fast. Just my 2 cents.
To Corvette Central
