Dyno Results
Old Oct 18, 2002 | 12:48 AM
keekster's Avatar
keekster
Default Dyno Results
Dyno Results
Max Power =270
Max Torque=301
107000 Miles
Only thing I am worried about is one run had a A/F of 11 and another of 11.6. Anyone know what could be going on ?
I would post a picture if i knew how
Old Oct 18, 2002 | 01:24 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Dyno Results (keekster)
At least your A/F is safely on the rich side.
BTW, could you contact the dyno shop and get the actual dynojet run files and e-mail them to me? I collect them. I am going to venture a guess however and say 100% bone stock LT1.
Old Oct 18, 2002 | 01:26 AM
vader86's Avatar
vader86
:cheers: :cheers:
Old Oct 18, 2002 | 01:41 AM
Nathan Plemons
I'd be willing to bet that the graph looks a whole lot like this.
If you have a scanner and have scanned the image but don't know how to post it, I'd be more than happy to help out. If you just have a paper copy if you can get me the files from the shop I can make my own graphics and post them as well. :cheers:
Old Oct 18, 2002 | 02:19 AM
keekster's Avatar
keekster
Default Re: Dyno Results (Nathan Plemons)
Thanks Nathen,
I will take you up on the posting help tommorow. It is bone stock down to the paper Air filter. :) That is exactly what the graph looks like.
[Modified by keekster, 6:20 AM 10/18/2002]
Old Oct 18, 2002 | 04:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You're running a little rich so a K&N and cut lid will likely lean it out nicely at WOT.
Then a nice cat back should put that A/F ratio just where you want it.
Old Oct 18, 2002 | 07:26 AM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: Dyno Results (65Z01)
Well, the above would work for about 10 minutes until the computer made some adjustments. Then she'd be right back to where she started.
One thing that may help a bit is new O2 sensors. I've heard that as they degrade they start to return "lean" information (i.e. they send out a lower voltage signal than if they were new... all things being equal). This would cause the engine to run a bit rich as the computer tries to compensate for the perceived lean condition.
Old Oct 18, 2002 | 07:10 PM
keekster's Avatar
keekster
Default Re: Dyno Results (Dan Parker '96)
I was thinking O2's also I will try that thanks :)
Old Oct 18, 2002 | 07:18 PM
TIMSPEED's Avatar
TIMSPEED
Computer ignores 02 at WOT.
Old Oct 18, 2002 | 07:23 PM
keekster's Avatar
keekster
Default Re: Dyno Results (TIMSPEED)
What else should I look at ?
Old Oct 18, 2002 | 09:25 PM
jstkrsn's Avatar
jstkrsn
Where did you get your car dyno'd. And at what cost. I'd like to get mine done also.
Jim
Old Oct 18, 2002 | 10:33 PM
keekster's Avatar
keekster
Default Re: Dyno Results (jstkrsn)
GRC erfomance of off Via Fabricante. It was 45.00 dollars.
Old Oct 18, 2002 | 10:58 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
That is the flattest looking torque curve I have ever seen!
Looks good! :cheers:
Old Oct 18, 2002 | 11:23 PM
65Z01's Avatar
65Z01
Though the ECM ignores O2 sensor data at WOT, to determine injector pulse width it looks at:
-coolant temp
-MAP sensor
-TPS
You can use a scan tool to look at these parameter values at WOT as well as assure that the BLM cell is #15 with a value of 128 and the Integrator value is 128, which says that the ECM is ignoring O2 sensor data.
Old Oct 19, 2002 | 04:12 PM
jstkrsn's Avatar
jstkrsn
THanks Keekster, I'm adding a pair of SLP shorty headers and I wanted to get a before and after.
Jim
Old Oct 19, 2002 | 04:37 PM
keekster's Avatar
keekster
I am intrested to hear your results with the headers please let me know.
To Dyno Results
