1990 zr1
Old May 14, 2018 | 02:29 PM
gLomeli's Avatar
gLomeli
5th Gear
Default 1990 zr1
I have a 1990 ZR1 with 17000 miles. There is a knocking noise around flywheel area and a mechanic thinks it may be the crankshaft thrust bearing. Can you advise on signs of this problem and cost re: repairs? I find it difficult to believe it can be this problem with such low mileage...,Thanks
Old May 14, 2018 | 03:04 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the forum and congratulations on your C4 ZR1!
You should post your question in the C4 section of the forum. Lots of great members and helpful info there. https://www.corvetteforum.com/forums...-1984-1996-19/.
Best wishes that this is an easy and inexpensive fix.
You may want to add some other info that could help the members there better address your concern, such as:
Does the noise appear all the time? Is the noise more noticeable when the engine is cold or when it's hot? Is the noise RPM dependent (more noise with more engine RPM)? Is the engine running rough? etc
Old May 14, 2018 | 05:46 PM
Moved to C4 Tech.
Old May 14, 2018 | 06:02 PM
C409's Avatar
C409
..... I'm pretty sure that the LT5's used a dual mass flywheel and they are prone to making strange noises .....
Old May 14, 2018 | 06:14 PM
gLomeli's Avatar
gLomeli
5th Gear
Thank you all for your great input. I just received a call from my mechanic who found that the issue was with the flywheel. Won’t be cheap to repair, but much better than a thrust bearing or other engine problem!
Old May 14, 2018 | 07:44 PM
ChumpVette's Avatar
ChumpVette
Probably not the flywheel either. ZR-1's are prone to making the noise you describe with a misfire. Check plugs, plug wires, coils, and injectors.
Old May 14, 2018 | 08:51 PM
gLomeli's Avatar
gLomeli
5th Gear
  • will do thanks
Old May 14, 2018 | 10:15 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
When I first got mine, the dual flywheel noise scared me until I learned what it was. Now, I listen for it as it tells me everything is normal.
Old May 14, 2018 | 10:37 PM
gLomeli's Avatar
gLomeli
5th Gear
Old May 15, 2018 | 07:55 AM
C409's Avatar
C409
..... I have also heard that the ZF trans can be noisy if the wrong oil is used .....
Old May 15, 2018 | 11:11 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Yes the DM is noisy the 90 had a black tag ZF6 also noisy and a miss fire will make it worse.
http://www.zr1.net/forum/
Old May 15, 2018 | 12:34 PM
383vett's Avatar
383vett
A bad thrust bearing would result in increased crankshaft endplay which can be checked in one minute with the car on a lift.
To 1990 zr1
